misscluedo
- Oct 6, 2014
Hi there,
I'm having a clear out and planning on selling these items...
- Jamo E7 Sub Subwoofer
- Two Mordaunt-Short Aviano 1xR bookshelf speakers
- Teac full HD Digital video DVD reciever DRH3381
Plus all the cords that came with them!!
Trouble is, I didn't buy them (my ex boyfriend did) and I am not sure of their value. They are in excellent condition and were purchased over the last two years.
All I know is that he had to order them in from overseas and they were expensive. I've tried searching trademe and other sites to get an idea of their value but because I think they were high-end overseas stuff nobody seems to sell them here.
Can anyone give me an idea of their value... or if there is a better forum/website where I could find this out.
Sorry if I am in the wrong place.
Jamo E7 Sub
The Jamo E7SUB Active Subwoofer is powered by a class A/B amplifier capable of delivering a stunning 675W of peak power. This ensures effortless bass reproduction with total realism. Its Boundary Gain Compensation (BGC) switch helps deliver a very linear in-room bass response, giving you more flexibility when it comes to choosing your favorite listening position.
The E7SUB cabinet is made of ultra-rigid MDF board, enhances rigidity while minimizing unwanted cabinet resonances and standing waves.
10" Woofer
Backed by a massive dual magnet, the high-excursion 10" woofer is fitted with a rigid air-dried paper cone. Whether it's with movies or music, this sub knows how to deliver the goods.
Controls
A comprehensive range of controls makes it as easy to integrate the E 7SUB with large floor standing speakers as with small high quality compact speakers.
Amplifier
The E 7 SUB is powered by a class A/B amplifier capable of delivering a stunning 675 watts of peak power. This ensures effortless bass reproduction with total realism.
Boundary Gain Compensation Switch
Helps deliver a very linear in-room bass response. Also gives you more flexibility when it comes to placement and in choosing your favorite listening position.
Mordaunt-Short Aviano 1xR speakers
The result is a more confident and clear, powerful sound - ideal for a stand-mounted speaker. And a sound that copes that bit better no matter where it's placed in any room. The Aviano 1 XR - greatness... plus a touch more.
Teac full HD Digital Video DVD Receiver
TEAC’s DR-H338i combines a DVD player with a receiver and Dolby Virtual Surround Sound for great digital video and audio in one compact component. Play CDs or DVDs right in the unit, and plug the HDMI or component out to a video monitor for crisp display of your videos.
Two aux inputs join a USB input for additional music sources. Plug an Apple iPod, iPhone or iPad into the dock interface for playback from these devices. A stereo amplifier provides 50W per side to your speakers, with a massive Toroidal power transformer for plenty of power. Dolby’s Virtual Surround Sound technology is included for an enveloping theater experience.
Whether you enjoy music or movies, the TEAC DR-H338i provides a complete entertainment system in one component compact enough for any home or office.
Jamo E7 Sub
10" Woofer
Controls
Amplifier
Impedance | 22k | |
Weight (Kg/lb) | 21/46,3 | |
Woofer (mm/in) | 254 / 10 | |
Frequency Response (Hz, +/-3dB) | 40 - 150 | |
Rated output (W) | 675 peak | |
Overall Dimensions (mm/in, HxWxD) | 375x375x375/14,76x14,76x14,76 | |
Mains voltage (EU/US) VAC | VAC 115 | |
A fine-tuned upgrade of the best-selling, award-winning Aviano 1 with an all-new crossover for an even cleaner sound.
At Mordaunt Short, we constantly strive to improve on the great products we produce. That's why we took the best-selling, award-winning Aviano 1 and tuned, tailored and tweaked it to create a very different speaker, yet one still cut from the same cloth. The "XR" comes from its redesigned crossover - an all-new configuration that delivers noticeably less overlap between midrange and tweeter.The result is a more confident and clear, powerful sound - ideal for a stand-mounted speaker. And a sound that copes that bit better no matter where it's placed in any room. The Aviano 1 XR - greatness... plus a touch more.
Drive units | Tweeter: 1 x 25mm (1") aluminium dome tweeter Woofer: 1 x 130mm (5.25") aluminium CPC, woofer |
Frequency response | 55Hz - 22kHz |
Sensitivity | 89dB |
Nominal impedance | 8 ohm compatible |
Crossover | 2nd order |
Recommended amplifier power | 15-100 Watts |
Ported | 1 rear |
Weight | 5kg (11lbs) |
Dimensions (h x w x d) | 275 x 179 x 267mm 11 x 7.2 x 10.7" |
Available Finishes | Black |
- Minimum 50w + 50w (4 ohms)
- Dolby™ Digital Virtual Surround Sound
- Frequency Response: 20-20kHz
- Signal-to-Noise Ratio: >90dB
- AM/FM stereo tuner
- HDMI: Out x 1 (ver.1.2, 1080p)
- Component Video: Out x 1
- Composite Video: Out x 1
- Analog Audio: In x 2, Out x 1
- Digital Audio: Out x 2 (Optical, Coaxial)
- Subwoofer Pre-out: x 1
- iPod Dock Interface: x 1 (Mini 18-pin)
- USB Port: x 1 (MP3/WMA)
- Binding-post Speaker Terminals
- 1/8" Headphone Jack
- Dimension: 8-7/16"(W) x 4-5/16"(H) x 14-3/16"(D)
- Weight: 9.1 lbs. (4.1kg)
