MacDEF
Headphone Hussy (will wear anything if it sounds good)
- Jun 26, 2001
TheeeChosenOne, do you have stock in Denon or something?
You keep hammering away at that Denon unit over and over, but I don't think you're listening to PianoBlack.
I don't mean to sound irritated, but it bugs me when people get so dogmatic about audio that they forget to tailor their recommendations to what the user actually wants/needs. I couldn't really care less what PianoBlack gets. If she doesn't like my suggestions, or doesn't take advantage of them, that's fine with me, provided she gets something appropriate for her that she's happy with in the long run. I have no vested interest in her getting the L40. The problem is that she has said over and over that she wants/needs something smaller, and that this system will be moved around a lot. By continually pushing big separates, you're pushing her in a direction that doesn't appear to be right for her. Even worse, because it doesn't look like she's going to be using this system for a big home theater system, you're advocating that she get a system that is more expensive but will probably provide inferior sound for two-channel listening. If you're really convinced she should get separates, then at least advocate for a good inexpensive two-channel amp (Arcam, NAD, etc.) that will sound better than that Denon receiver for two-channel listening.
PianoBlack, one other thing you might consider is the Denon DM-30
In the hierarchy of "minisystems" it's probably the best one until you get to the L40. The great thing about it is that it's really small, but sounds very good and includes a set of great Mission speakers. Sorry to add to the confusion. The L40 sounds significantly better, but you can get the DM-30 for around $300 complete on sale, so maybe something like this would be good for school... later when you have a house or big apartment (and more money), you could buy a better "main" system, and still keep the DM-30 (or L40) around for your bedroom or kitchen.
P.S. TheeeChosenOne, I want to address a couple of your points, which I feel are very common misconceptions in audio.
The issue of "what if an all in one breaks" is for the most part not a great argument. It's one of the old myths used by people to justify separates, when separates are not *always* the best way to go. It doesn't cost any more to get the CDP in an all-in-one fixed than it does to get a standalone CDP fixed (and whether your CDP in the all in one breaks, or a separate component CD player, the fact is that you can't listen to CDs until it's fixed
). But even more important, all-in-one units are simply better for some people. I personally have separates, and have had them since I was 14 years old (a long time ago) when I mowed lawns and did odd jobs for two years and bought an integrated amp, a separate tuner, and a separate tape deck. But I also own an L40 because in the place where I use it, small and compact is better than a bunch of bulky components. I've suggested to a few friends who needed small systems that they buy a Denon DM-30, because it's even smaller than the L40 and for the money can't be beat. The "separates are always better" argument is dogmatic and not applicable for all people at all times.
As for your listing of various "reviews" of the L40 vs. the Denon, you're comparing products in *completely* different categories. You can't compare a 3/5 rating for a two-channel audiophile-level minisystem with a 5/5 rating for a Denon 6-channel digital home theater receiver. They do different things, and are intended for different purposes. It's like comparing the crash tests results for a Hyundai Accent with a Ford Explorer: the Hyundai gets 5/5, while the Ford gets 3.5/5. But those ratings are class-specific--the Ford is MUCH safer than the Hyundai. In fact, I guarantee that for two-channel audio, the L40 will sound better than the Denon. In addition, your review references have been heavily biased towards the product you want PianoBlack to buy --the Denon has received reviews with less than stellar ratings, while the L40 has received many more high ratings than not. My point here is that both are very good products, but products made for different applications. Given PianoBlack's stated preferences (smaller, mobile, two-channel), I just don't think a bulky home theater receiver, which would then require another component for CD playback, is the best way to go.
Best,
Mac
Best,
Mac
