Need advice for HD668B inserts in front of driver for treble
Apr 25, 2020 at 10:19 AM Thread Starter Post #1 of 1
BigBig5
I have a pair of HD668B that I modded some.
Mods:
  • Added electrical table inside the cups covering the holes. This lowers the sound stage but not too much and helps control the sound.
  • Removed paper inserts in the cups because not needed with 1st mod
  • Removed foam inserts. Clears up the sound, helps to tame the treble somewhat, and also, bringing the mids forward.
  • Replaced stock earpads with Tranesca leather Angled big overear earpads. This gives comfort over the cheap stock pads
  • Resoldered the poorly done wires for a better lasting connection.
I ordered some BRAINWAVZ XL PU leather to replace my recently peeling earpads but hasn't arrived yet. I notice with some EDM songs but not all can have hot/harsh treble if mids/lows aren't playing at the same time. In foobar2000 I used to set EQ to help bring down treble some. Now I don't want to rely on an EQ because I use multiple devices and OS's to listen to music. What materials for DIY inserts should I use that would help with treble? I have heard of using coffee filters but that has different results depending on the model of headphones. Also, I don't have the foam inserts anymore.
