Navyblue
- Apr 2, 2008
I am looking for a tube/hybrid amp. It will be primarily used as a preamp in my speaker setup, so transparency and detail is top priority here. Driving headphone is a bonus so power output can take a back seat.
I would prefer that the amp provide a sound different from a solid state amp (that I already have).
As mentioned it does not have to be uber powerful, "quality" is what I am after. I don't really know how much to spend here to get sufficient "quality", hopefully not too expensive. I don't rule out DIY too if I have to get the kind of quality without getting too expensive, as long as I can good support on the topic. But doing high voltage is something that kind of bothers me (although the hybrid seems not as bad).
I have a Little Dot Mk I portable amp, the soldering work is atrocious, it worked but has battery life problem, I sent it for servicing, I don't know if they solved the battery life problem, because it's dead soon after it came back. So needless to say Little Dot stuffs are an automatic no unless you have something to back their quality and workmanship (rather than it just looked pretty outside and worked).
I am looking at the Darkvoice line, how are they in terms of "quality"? Specifically the 336SE and 3322.
Thanks.
Thanks.
