csj0952
- Sep 12, 2011
Can I get a couple of options under $400 for a portable headset/headphone that has a good microphone and decent passive noise cancellation in the ear as well as in the microphone blocking out background noise (prefer something that has the two mics to listen to ambient noise and block it out).
Prefer non EIM but would consider it so give me a couple options if you have them. Would be great if the headset folds up similar to the Sennheiser MM 450-X travel. This headset looks good for me but I'm not crazy about the built in battery and active noise cancellation. Has to work on a 3.5mm jack.
What else would you recommend? I'm mostly going to listen to music and take calls on my phone for business.
Thanks,
Chris
Thanks,
Chris
