IEMs are not an options I already own sennheiser IE8 and it really irritate my ears for longer listening.
Why not sell the IE8 and just try another IEM that might be more comfortable? Anyway it's for portable use, it doesn't have to be a huge reference headphone.
Or maybe get an over-ear or any compact but more importantly easy to drive headphone if you don't want to take a chance on IEMs. Something like a Sennheiser HD25 or Philips SHP9500S.
Then keep the HD600 for use at home. Save up for a desktop, AC-powered DAC-HPamp to drive it.
Btw do you know if there exists any DAP powerful enough that could drive HD600 alone without the need of other stuff ?
Maybe the Fiio X7 with the AM5 module but even that isn't really going to be as good as, say, a Little Dot MkIII (on the flipside, the MkIII isn't that good in case you want a low impedance, low sensitivity headphone).
Or at least give me some suggestions of proper portable sources that could work with an amp or amp/dac like corda quickstep..
Maybe check if the Fiio M3K will output via USB digital into the PCstep (Quickstep is amp only). It won't have the same DSP features as your Cowon though. In which case...why not just use a smartphone? Buy the right cable and your phone might work.
There's also the Fiio M7 and M9 with line out to the Quickstep.
selling HD600 is not an option because of the location I live on. And Im gonna lose a lot from the price if I do that.
I'd just sell the IE8 and get an SHP9500S.
Im getting kinda desperate to make the things work
. And in the end what exactly do I need for amping.. dac or dap ? I guess the dac is not a player.. so I need a player with dac which could be paired with an amp ?!! I give up.. I dont understand anything
. All I want is..to find a way to move around with my HD600 and enjoy them.. there have to be a way..
There
are ways.
It's just that they're
not cheap either.
I mean if you really want to be able to walk around with the HD600 like you're listening at home you'd probably have to go with something like an ALO Continental or RSA Intruder, with the appropriate source (the latter might work with just a smartphone). Maybe hunt down an old pair of Ibasso Boomslang and Toucan and carry three devices connected by cables.
Bare minimum to have more power while retaining comparable, if not more, DSP features than JetEffect (through other apps) is a Fiio X5III with a Fiio A5 amp.
I increased my limit .. and so Im looking and more expensive options now. I found Astell&Kern AK70 MKII DAP .. which have balance output 4 Vrms .. which sounds good since you need like 2 Vrms to drive properly HD600 so its almost double.. just have to find if anyone already tested it.. and probably that will be my thing.. if it works of course.
If you use a lot of the Cowon DSP features an X5III and A5
might work better, not to mention you get more power without having to blow money on a balanced cable.
