PaulDenton
Hello,
Just recently decided to order both Cayin N3 and Chord mojo but need some advice concerning the cables to connect the 2.
It seemsthat one option would be to use Type-C to 3.5mm Coaxial Cablebut it is not easy to find one in europe, there is a place on the internet from where you can pre order them but god knows how long will it take for them to start shipping them out.
Would you know where could it get one?
Secondly i was wondering if there are some other ways to connect them, maybe via mojo USB? (type-C to Micro USB but would it work as type c to coax does?
Thank you very much, any info is well appreciated!
Cheers
Cheers
