Toonartist
Formerly known as dAndis67
Just to add, I'm not using my Atom HE with focal headphones but with Meze Elite and they sound extremely good compared to Chord H2 & TT2.
My only experience with the Newtopia was at my local dealer using the HE as sole source, in direct A/B comparison with the OG. I did prefer the New over my OG, and didn’t find the combo with the Naim to be too warm. But as always YMMV.As others say, the Naim Uniti Atom HE is a great all-in-one device that was tuned with Focal headphones in mind, but it was done so *before* the NUtopia came along, so its tuning was most likely done with the OG Utopia, whose synergy with the Atom is indeed near perfect, but I also heard both headphones on the neutrally tuned DCS Lina stack, and there the OG sounded too bright and lean to my ears (though never hardh), while the NUtopia appeared to be a great match. With this I’m not saying you should land yourself in the poorhouse with the Lina and the NUtopia, but you might find the NUtopia/Atom HE combo a bit too warm, lacking sparkle. I know I did, and decided to stick with the OG Utopia for my Atom HE… or you could match the NUtopia with a more affordable neutral DAC/amp combo.
I’m pretty sure the tuning wasn’t just with the original Utopia but the full line up of Focal headphones and I’m sure they tested with other headphones as well. It sounds excellent with the DCA Expanse and other said Meze Elite. So this was designed as an all around headphone system. With that said, it is one of the warmer solid state amps I’ve heard but I think that’s just Naim’s house sound. Thick bottom end, rhythmic, rich mids, smooth highs, and decent resolution but not the last drop. Tube-like.As others say, the Naim Uniti Atom HE is a great all-in-one device that was tuned with Focal headphones in mind, but it was done so *before* the NUtopia came along, so its tuning was most likely done with the OG Utopia, whose synergy with the Atom is indeed near perfect, but I also heard both headphones on the neutrally tuned DCS Lina stack, and there the OG sounded too bright and lean to my ears (though never hardh), while the NUtopia appeared to be a great match. With this I’m not saying you should land yourself in the poorhouse with the Lina and the NUtopia, but you might find the NUtopia/Atom HE combo a bit too warm, lacking sparkle. I know I did, and decided to stick with the OG Utopia for my Atom HE… or you could match the NUtopia with a more affordable neutral DAC/amp combo.
I use mine over Wi-Fi now. I used a good high end cable before but didn’t notice any drop in performance with Wi-Fi… maybe a slightly better noise floor.I remember reading somewhere (can't remember where) that someone concluded that the Atom HE sounded better over Wi-Fi than over ethernet... Wonder what the consensus is on that....![]()
I prefer wifi but can’t really say I could tell the difference.I remember reading somewhere (can't remember where) that someone concluded that the Atom HE sounded better over Wi-Fi than over ethernet... Wonder what the consensus is on that....![]()
I can’t compare but I can say I wouldn’t call the Naim HE lush. Probably need to get a tube amp for that. What it does have is the so called PRaT sound. Pace, rhythm and timing. It has great weight with nice bass texture. It has a slightly thicker sound than other setups and might take a little getting use to. The details and layering don’t jump out right away because it’s not as bright and airy as some setups. But you will hear the detail in time and it does bring you into the music. You’ll first hear the rhythm of the music and be drawn in that way.I own M17 and Focal Clear / Audeze-X. Looking to buy Naim Uniti Atom HE. What can I say that M17 is very precise (technical presentation) and powerfull, especially in DC mode. Sound is detailed with all nuances but personally for me it lacks a bit musicality and soul, not so "lush and warm" presentation. That is why I'm searching for another powerfull device - all in one, with hint of musical, lush, lively, soulful presentation.
Has anyone compared M17 to Naim Atom HE in terms of sound? That would be very interesting for me to know more about this comparison...![]()
I’ll second @iamoneagain.I own M17 and Focal Clear / Audeze-X. Looking to buy Naim Uniti Atom HE. What can I say that M17 is very precise (technical presentation) and powerfull, especially in DC mode. Sound is detailed with all nuances but personally for me it lacks a bit musicality and soul, not so "lush and warm" presentation. That is why I'm searching for another powerfull device - all in one, with hint of musical, lush, lively, soulful presentation.
Yeah, I guess you can call the bass lush. It has this tube-like bloom to it. The mids are also nice and rich. It has the kind of sound that washes over you and surrounds you.I’ll second @iamoneagain.
The sound is musical, detailed, and very addictive. It drives the DCA Stealths with ease.
I would say that the bass presence and tone through the Focal Utopia is more “lush and warm”. It’s not to tube levels and it’s not euphonic. The HE definitely warms up the Utopias a bit. As mentioned, the PRAT is still excellent with the Utopias. I’m sure the Clears will be pretty close in comparison.
I’d demo it if possible.
What kind of tube amp are you pairing to the HE?Having added a tube amp to the Naim Atom HE, I feel it has similar tones but only in that it has a little more warmth to it but isn't an overly "Warm" amp.
@iamoneagain sums it up well. I find the HE to provide great PRaT, soundstage, imaging and detail. The detail might not be as in your face as other amps but it's also easy to listen to for 8hrs at a time without fatigue. Adding a good power cable really helps bass texture, soundstage and imaging.
The HE really shines in terms of functions and usability. It links up with everything perfectly and is a great preamp!
As @iamoneagain says, set the volume on the Atom HE to about 60-70 then adjust the headphone amp volume to what is comfortable for you then use the Naim remote to turn the vol up and down. I'm using RCA preamp out of the Naim HE an it works very well indeed.What kind of tube amp are you pairing to the HE?
My concern is that if I’m not using an actual amp, I’m somewhat double amping the signal. i.e. if I want to use the Naim as a streamer DAC into the Folkvangr or Woo WA8. I’m not aware of a line out mode on the Naim.
