mz-n910 Charging without a charging stand
Jan 18, 2012 at 9:16 PM Post #2 of 13
Get a charger that charges Gumsticks?
http://www.onlybatteries.com/showitem.asp?ItemID=13287.14&cat1=57&uid=1692&utm_source=google+product&utm_medium=versafeed&utm_term=13287&utm_campaign=electronics+electronics+accessories+power+batteries&utm_content=hitech&v_traceback=c0117_0235_f0117_0355&sid=GoogleShopping
Jan 18, 2012 at 10:00 PM Post #9 of 13
i would guess your battery is maybe finished and charging doesn't do anything anymore.  I have a Sony MZ N10 (internal battery) and I charge it o the charging stand for 6 hours and in less than 20 minutes the battery loses juice on its own from playback.
Jan 18, 2012 at 10:04 PM Post #10 of 13
screw, i use few years a 5v adapter, for external power, which i received with pleer. and i was need only 3v to charge? sth i was very inconsiderate, i will buy 3v adapter, and test it, thank you.
Jan 18, 2012 at 10:06 PM Post #11 of 13
don't get too mad just yet.
Try
I used to have a md recorder that did this too.  You have to press stop to charge the device.  And you cannot use the device while it charges.
Jan 19, 2012 at 2:50 PM Post #12 of 13
Yep that should be it. If you still have the adapter you are good but, as mentioned, you need to press CHG to start the charging. The N910 is a very nice unit, btw. A charger like I mentioned before is also a good idea since it charges other types and you can charge a second gumstick outside the unit and just pop it in since you can't charge and play at the same time.
Aug 13, 2022 at 7:22 PM Post #13 of 13
Just got this Minidisc in nearly new condition and if i try to charge without the stand it will "stop" charging earlier, because if then put it on the stand it continues to charge for some time, dont know why.
