sinky
- Apr 20, 2013
Hi all I updated my x5 yesterday to the latest 2.2 firmware (was sitting at 1.2 since June and had no problems with my x5 )
I updated as the new firmware has support for dff files.I already had my dff tunes on my 64 gig sd card my x5 was fully charged and had downloaded the 2.2 firmware and stuck it on another 64gig card formatted in the x5. I switched the x5 off then pushed top left button then help power on button and x5 started updating then rebooted ,when into system settings to check firmware 2.2 was there and had a look around settings to see what was new.stuck in my sd card full of dff files and updated library,then using folder view
went to my dff files ,they all played and everything sounded great.The player seemed a little more sluggish playing dff files but thought that normal with the extra processing required,flac was noticeably quicker .
Everything seemed fine till the next day when I tried to power it up ,no welcome screen came up ,blank screen and no power up .so decided to try reset switch for the first time then power up ,still nothing.plugged it back into my pc ,and x5 powered up saying usb connected and pc recognized my x5.
Unplugged my x5 from pc and tried to power off ,not working x5 remains on hmmm getting worried now.
left x5 on idle and set it to power down after 2min,removed sd cards and booted it up using usb as this it seems is the only way the x5 will power up now.did factory reset ,x5 still the same.downloaded 1.2 firmware off FiiO to roll back then remembered that you need to hold the top left button and the power button to load update,tried it anyway(it didn't work)
I got know idea what to do now.
Apart from the power button not working x5 still functions in all other ways although I noticed that screen lock 1 won,t work using both the volume buttons but the volume buttons themselves work fine when playing music.screen lock 2 and 3 work fine.
