Anaxilus
- Mar 12, 2010
It may so happen that the sort of changes that typically occur over time and use are the sort of changes that tend to correlate with either 1. actual physical technical improvements, or 2. some physical changes that are perceived and interpreted as improvements.
I won't give examples of the first possibility because I don't have the data to do it, but I would speculate a bit on the second possibility, maybe people like smoothness or a sense of continuity without the harshness of real music, so perhaps simply wearing out the drivers past "whatever is considered technically most accurate" tends to make people like the sound more? Or maybe when highs become less piercing or distinct, it becomes easier to consciously focus on highs, so that although there is actually less highs, there is the perception of more high freq resolution.
I give these two possibility just as an alternative to the argument that "because burn-in is almost always perceived as an improvement, it must be placebo".
I totally agree with you on that point. I need to differentiate between the hope for improvement versus the perceived factual knowledge of the end result. It is not dissimilar to engine break in on a car. The engine will not run at peak efficiency or performance until the compression rings seat, bearings and seals set, etc. Those events are a result of engine wear. All car engines are given a run in before they ever get to a dealer. These are simple mechanical properties which will have a varying degree of impact on a case by case basis.
