gregorio
- Feb 14, 2008
Sorry but that makes no sense at all. There is no musical signal, there is only an analogue electrical signal and cables do NOT render anything, they just transport that analogue signal from an output to an input. And if that’s not bad enough, soundstage and density of image are human perceptions, not properties of an analogue signal and as cables don’t have any human perception obviously that cannot be measured when measuring a cable. Obviously you would have to measure someone’s brain for that, not a cable!But simply keep in mind that frequency response is only one aspect of how different cables render the musical signal. Other differences can include soundstage, density of image. Items we have little measure for (although phase is relevant here). Quality differences.
Well, well, well indeed! So, you claimed: A massive difference, not just a barely audible difference but a difference so huge it hurt your wife’s ears in the treble/sibilance range. You also claimed that “copper brings out the mids and sounds warmer”, sibilance also covers the mid/treble range (roughly 2kHz - 9kHz) and in addition, your cans have a very strange impedance curve centred around 2kHz. So, all this seems to correlate and provides some food for thought and yet throughout the range from about 600Hz to around 11kHz your measurements indicate pretty much no difference at all, let alone the huge/massive difference you claimed, “Well well well” indeed!!!Well well well... what do we have here.
Incidentally, the slight difference of 2-3dB between roughly 90Hz - 400Hz is well within the margin of error. As explained when I suggested this simple/easy measurement approach: “This is hardly a very accurate methodology but should be ample to show the huge mid/treble boost you’re claiming.”. Also, the very narrow dips at around 15kHz and 17kHz are indicative of phase cancellations, due to reflections caused by a small change in relative position of earphone to mic.
What really is “patently stupid”, is having no knowledge/understanding of acoustics then coming to a sound science forum and arguing/insulting others about it! Will you never learn?There's the first pathetic excuse! (as if a 35dB difference would be within the "margin of error of the setup"). Your point is patently stupid.
That is indeed awesome. You claimed a huge difference in the mid/treble, measured pretty no difference at all but refuse to believe this factual (albeit crude) evidence on what grounds, that you’re “blind to bias” and therefore not a human being?In the meantime I’m still in awe how some people refuse to believe factual, scientific (albeit crude) evidence that also happens to be backed by the subjective opinion of a person who had no background in the subject matter (therefore blind to bias).
Agreed, the differences that exist between cables (of the same type, length, etc.) are tiny compared to the margin of error when trying to measure HPs with a mic, so it’s a pointless/misleading exercise. However, in this case the poster isn’t claiming tiny differences (that he believes he and his wife can hear), he’s claiming “huge differences”, differences so large (in the mid/treble range) they hurt the ears. Such a massive difference should be detectable even with this crude measurement methodology.I think this and the other threads are great examples of why "measuring cables" (with a microphone or with your ears nonetheless) this way is not a great idea.
G
