My "omega" style headphone stand with O2 Amp
Mar 15, 2013 at 11:42 AM Post #19 of 25
just wondering did you glue the amp in there? Or its a tight fit? amazing job !
I think he's not using the enclosure of the amplifier. He mounted the PCB to the faceplate, then mounted the faceplate to the wood using te 4 screws at the corners.
Apr 11, 2013 at 8:02 AM Post #23 of 25
I actually mounted the aluminum case inside the stand. The case I bought is a little longer than the one recommended for the O2 because I wanted the overall depth to be longer. The case has slots for the pcb to slide into and I could also ground the board as well. I don't like to put place bare electronics so close to wood, even if it is low voltage. I'll post pictures later.
Aug 22, 2013 at 11:10 AM Post #24 of 25
Hey I admire your craftsmanship on this!!
This is the first DIY headphone stand I have seen that I would build my self.
Do you still have the template you made? If so could you send it to me?
I would like to try to build this my self.
