m11a1
- Jun 3, 2007
Hey guys, for the past couple weeks I thought about getting better cables from my amp to the CDP, but then an idea came up, instead of buying a cable that is worth $400 for half a meter, why not making my own?
So I did it: I used 2 pairs of gold rca connectors made my RCA. Monster XP speaker cables. I took out the strands of the speaker cable and shoved them in a teflon tubes.
I crimped the speaker cables here on the rca connector.
I placed a heat shrink on the area where the speaker cable and the connector is in contact.
And then I screwed on the cover....whatever it's called.
Here you can see the complete pair...haha its not even balanced in length.
Here, it's connected to the amp and CDP:
A closer shot of the cable in use:
I tried listening to it on my GS-1000 and it sounds good, actually glad that it works, knowing for sure that I did it right
, it seems more detailed and richer than my old cable. So anyways, that was my lazy job of quick DIY interconnect. But I think I should be much more serious for my next DIYinterconnect. Can you guys give me some suggestions or advice for my next cable? And also, where can I buy more and better parts (connector, cores, teflon sleevings ...etc)?
Thanks!
Thanks!
