Karlosak
- Mar 26, 2003
Hi,
I've finished my first DIY project: a CMOY for my HD-600. And it is better than I expected. It can really show up the power!
But I still have some minor problems:
1) At 9V voltage it had quite problems with higher dinamic passages - I got distortion (maybe oscilation?). But when changed to 2x9V it performs the hardest music passages easily and the sound also cleared up. Is it normal? Or due to oscilation problem? (After all, It doesn´t matter much - I can stick to the higher voltage and enjoy)
2) I´m using the ALPS 10K logaritmic pot (STRK09707 - the cheaper and smaller brother of the Blue Velvet) and have difficulty setting the volume - first it goes rapidly up then still the same level (cca. 60% of the range) and at the end it goes dramatically up. What´s the problem? I've wired it the same way as the Blue Velvet in META board. Is it possible that I´ve changed the logaritmic dependence vice versa. But if I change the ground with the out (on the pot) then I will have to turn it anti-clockwise (and I don´t want to). I´ve measured it and it looks like correct: turned left it has O Ohm (no voltage on the input) and turned right it has 9.8 Ohm (full voltage on the input). So the only problem is the volume curve.
Please give me any hint. Sorry for stupid questions but I´m new to the DIY and can´t sort it out myself.
Thanks
Thanks
