sonicx2218
- May 11, 2012
Got a new schiit Asgard 2 amp after enjoying the cheaper magni 2 paired with my dac. I'm very confused as the magni's volume control alters the volume as expected, but the volume knob on the asgard 2 makes the sound either come out of the left headphone only on low, and out of both at max - no actual volume change - just sound orientation. Is it working ok and it should be set to max and the dac's knob controls the volume, or is something wrong?
