Head Injury
- Sep 11, 2009
what would you recommend? i have 596 dollars(summer jobs and allowance) saved up in my headphone fund.
This thread was made for you!
Before buying new headphones I would try changing the tips from the cheap earbuds to the sennheisers. Also if you don't know how to EQ you'll just make the sound worst, to start I'll leave it flat and play with the tone controls bass to 100% and treble 75%, and go from there.
yes i'm certainly getting a good fit, as i said before "the senny's sounds emmence+no distortion at like 95% volume and much better than the $20 headphones when on my laptop, i presume it's cas of the extra power" the highs are crisp and the lows are deep bold and powerful, i was just wondering if the amp could replicate the noise produced from my laptop?
sorry for the confusion, my phone does go loud enough, in fact really loud but without the app the sound quality is shockingly bad and sounds like i'm using $2 headphones compared to when i use both headphones on my brothers ipod 4th gen and on my laptop.
(the senny's sounds emmence+no distortion at like 95% volume and much better than the $20 headphones when on my laptop, i presume it's cas of the extra power, hence why i asked about the amp).
with the app i sounds so much better and the quality is amazing on my phone but distorts when you go above 60% volume but i want to go louder than 60% without the sennheissers distorting. what i'm trying to ask is do my sennheissers need an amp as i heard that IEM'S in this price region need an amp to perform at it's greatest. so basically do the sennheissers sound not as good because there harder to drive/run and need an amp to release it's full potential?:confused_face_2:
If you have realtek sound stuff, try going into the device properties
Then enhancements
Then check disable effects
