Ashkii21
- Apr 8, 2009
I recently built my first Cmoy amp as my first DIY amp (first time soldering anything significant, I think I destroyed the soldering tip) and I made a mistake when ordering the LED. I ordered my parts from Digikey and I used 160-1780-1 instead of 160-1708 LED, lol. Well everything seems to work fine, the amp works and the LED works also. (lights up and is at just the right brightness for me) I am using a 10 KΩ 1/4 W metal film resistor with the LED (Red 1W, 2.57 V, 350 mA, surface mount, $1.61). I tried figuring out the current with online LED/resistor calculators and I think that the LED is passing 0.643 mA through it. (9 V-2.57 V/10000) I am not sure if I calculated this correctly.
Is it .642 mA or 350 mA?
What are the effects of using this LED instead of the tangent recommended 2.0 V, 20 mA LED besides cost? (battery life?)
Should I run down to Radioshack and buy a 3mm Red LED, 276-026? ($1.49 + tax)
Also for this amp I am using an OPA2227PA, 470 µF 25 V electrolytic caps for C1, .47 µF 63 V metal poly caps for C2, 4.7 KΩ 1/4 W metal film resistors for R3 (gain of 3), no R5 (just a jumper) and using a 9 V battery. I am satisfied with this cmoy although I am using a different LED.
