Actually both cases involve multiplying frequency. Oversampling is a marketing term (as seen on old CD players), upsampling is a technical term, a special case of resampling or a sample rate conversion (SRC). Upsampling can be to any frequency (not limited to power of two numbers), this is a main difference.
So after a few months of listening, my final thoughts on this vs the Denafrips is that I like this one a bit better. I hear just a bit more dynamics and resolution. The catch is that it is really only a marginal difference - ie, I am not sure I could identify one over the other if A-B'ing them. But given the consensus high regard for the Ares, this is actually high praise.
The inclusion of the hdmi I2S connection, along with I2S configurability so that it is compatible with multiple DDCs are welcome features over the Ares. Its idiosyncratic looks are not a welcome addition though. Its weird angular shape and non-standard size kind of ruin the aesthetics of my equipment stack.
In my opinion, it is not worth doing what I did - ie, selling my Ares to get this. But if you have a DDC and are intrigued by the Denafrips sound, this gets you virtually the identical sonic signature as the Denafrips, but with a bit better performance. The only downside is its looks if that makes a difference to you.
I am surprised that this unit hasn't received the buzz that the Ares has - it really is a fantastic product that should be an easy decision vs the Denafrips.
Ironically, I will probably end up selling mine though. I have multiple R2R DACs and was looking for either a major sonic improvement over my Ares, or something that sounded different altogether.
Has anyone compared Draco with Pegasus, do they have any noticeable difference in tonality, timbre and speed?
Does Draco have the delay issue when connected via usb that Ares 2 has?
That reviewer talks about the lack of EMI filters in Draco, which neither Pegasus or Aquarius have. He mistakes the standby power supplies as filters. Such expertise...
They are. In the input of Meanwell SMPS. This circuit is needed for auto-switching between 220V and 110V AC. Draco do not have auto-switching feature, so it is why filter is also mising. I don't expect a reviewer to be an expert in electronics, do you?
The review is well made and I think Draco has better value than Pegasus.
I2s rocks on pi2aes mercury, f usb hundreds and thousands on noise reduction and cables. I might be one of few that got a lemon/less than ideal resistors noise : buzz clipping once in a while in all outputs i2s usbc, shut off and restart to get it back to normal. For what i'm getting , not complaining, lived with it.
