Musical Fidelity M 1 power amp.
Jan 21, 2014 at 10:36 PM Thread Starter Post #1 of 1
ACDOAN
Here the spec.
Stereo Mode
Output Power: 65W into 8Ω, 130W into 4Ω
THD: <0.03% 20Hz to 20kHz
Frequency response: <0.5dB 20Hz to 20kHz
SNR: >94dB, “A”- wtd
Crosstalk: 85dB
Mono Mode
Output Power: 100W into 8Ω, 200W into 4Ω
THD: <0.02% 20Hz to 20kHz
SNR: >100dB, “A”- wtd
Connections
Line level input: 1 pair RCA line in left and right
Line level outputs: 1 pair RCA line out left and right
Speaker outputs: 2 pairs binding posts
Trigger input: 3.5mm (⅛”) mono jack ±4.5 to ±15V DC
Trigger output: 3.5mm (⅛”) mono jack +12V DC
Power requirement
Mains voltages: 90-250VAC 50/60Hz
Consumption: 350 Watts maximum
Weight: 8.66 lbs.
Dimensions: 8.66" x 4" x 12.5"
I have no problem with Class D switch amp when pairing it with some tube pre amp.I like the 8.86 lbs due to the limited weight of my floor upstairs,
No serious review except a negative one from WhatHifi. Serious complaint from the end user is the annoying "whizzy" noise in stand by mode and harsh HF.
I am not a fan of MF house sound but the deal is so good $499.00 a pop. Please feel free to void your experience if you own one or two of these units.. Thank you.
