I disagree for this particular scenario. These coupling caps in combination with the input impedance of the amplifier being fed by the MP-701 form a high pass filter. By high-pass, to only pass in the frequency range you desire. In my previous post I commented about if you want to improve the bass output of the MP, you simply have to increase these capacitors withing Garry's provided range. (See my attached picture below, on how the coupling capacitor and the input resistance of that amp contribute to allow pushing the cut-off frequency of that high pass to get more bass or less of it. )
Here is where I disagree more. A capacitor has what we called an Equivalent Series Resistance (ESR). That ESR, the lower it is, the better. Why, because these account for some of the signal lost across that capacitor. Therefore, putting two capacitors in parallel causes the ESR of the resulting equivalent capacitor to decrease. In fact, you may notice in some design the designer chooses to put multiple small capacitors in parallel instead of using one big one for the same value, because he/she wants a lower ESR.
