alans
- Nov 24, 2015
output impedance of the Music Hall ph 25.2?
No one knows - it's not printed anywhere in the official literature nor in any review - and hence the point I've been making. Since there is a trend for speaker gear manufacturers to overlook this, and in many cases even when they make headphone amps and state the output impedance it's still usually a bit high (MF V90HPA is rated at 50ohms), it's safer to assume the output impedance is on the high side rather than low. You can risk it if you want to of course since it's your money, but as far as recommendations go, the safer bet is to assume it is likely higher than desirable.
