71 dB
I like a little crossfeed in my headphones. With speakers your ears get so much more additional information from the cross-channels, it would seem to me that headphones will always exaggerate the separation by comparison. I really like the Meyer crossfeed plugin for Foobar2000 (I'm using it now).
If anyone has any observations about the relative merits of the Meyer crossfeed plugin in Foobar2000 I'd be interested.
On my Behringer DEQ2496 DSP you can narrow the stereo image for headpnone listening in pretty fine increments, and adjust other crossfeed variables as well. Narrowing it just a little goes a long way toward me enjoying the music better. YMMV.
If anyone has any observations on using the Behringer DEQ2496 for crossfeed I'd be very interested to hear it.
I have never used Foobar2000 and it's crossfeeders, but I used Vox player which has three crossfeed options (Defaulf, Chu Moy and Jan Meier). Most of the time however, I used crossfeeders (based on Linkwitz-Chu Moy "X"-topology) incorporated into my DIY headphone adapters fed by my AV amp like speakers. That way I don't need headphone amp so it's very cost effective. I also have a tiny DIY Meier-Crossfeeder available between the pre-out and main-in connectors of my AV amp.
Jan Meier is a "H"-topology crossfeeder meaning it has different kind of sound than "X"-topology crossfeeders. "H"-topology crossfeeders sound more aggressive and wide. The sound is spead from left to right depending on the spatial information of the original signal, while "X"-topology crossfeeders emphasize ±30° angles simulating speakers. I prefer "X"-topology for it's softer and calm nature, but it really depends on the music style which crossfeeder topology is optimum. In winter 2017 I build a "wide crossfeeder", a variation of the standard Linkwitz-Chu Moy that simulates speakers that are at ±90° angles. Because the sound is "wide", this "wide crossfeeder" works really nicely with movie surround sound, but the downside is it lacks the forward sound feel stardard Linkwitz-Chu Moy has. Center sounds are located near your nose!
The ability to adjust crossfeed level is very important, because recordings are not the same regarding excessive stereophony. Some recordings don't need crossfeed at all, some just a little bit and some "ping pong" recordings need MASSIVE crossfeeding. Try different settings and trust your ears. It takes a minute or two for ears to adjust to crossfeed properly so don't jugde after 5 seconds. Just as there is speed blindness, there is excessive stereophony deafness. It means after turning crossfeed on, the sound may sound too narrow for a while, but after about a minute or so spatial hearing adjusts to it. That's why even those who like crossfeed, tend to prefer mild crossfeed on everything, even when strong crossfeed is called for.
I don't know Behringer DEQ2496 DSP, but it seems it's just basic stereo separation adjust which is not proper crossfeed at all.
