holland
- Jun 15, 2007
Use the jack I linked above. Your switchcraft 3.5mm jacks tie the 1 pin to the screw barrel. Your case is at input and output ground level.
The -12 is actually 0, according to the wallwart. The +12 is 24V according to the wallwart. The TLE2426 splits it into half, creating -12V, VG (what is used as the 0 point for the opamp circuit) and +12V. The opamp circuit uses the VG as the ground point, so it is elevated 12V above what the wallwart thinks is 0V. It's just a bunch of reference points, and how you tie them together is what matters. This is what makes it important to isolate. You'll learn more as you do more. Some of the isolation carries over to dealing with wall electricity (120V), where the case is "earth" and you need to isolate IG/OG/etc. and use things like ground busses or star ground.
If you fried your TLE2426, you'd smell it and you would no longer see -12V, 0V, 12V, but something else or nothing at all.
