Ah yes, the "ignorance is bliss" crowd
There are good reasons to know whether you'd settle for lossy, though. Like if you have a portable device with limited space, and you'd rather not keep two versions of your music. Or if you want to know whether your iTunes Music Store purchases will sound any good (DRM issues aside).
But if none of this applies to you, or even if it does... hell, it's your music to listen to as you like |
As I pointed out earlier in this thread, unless you are prepared to test every single song on the component you are using for playback, the test is limited. If I cannot hear a difference on an AC/DC track, but I can on a Boston Pops track, then I know the results for those two tracks on the playback device that I used for testing.
I am not prepared to test 17,000 songs to see if I can tell a difference or not on my ipod and then on my main system and then on my office computer and then in the bedroom and then on my laptops and then in my car (the many places I listen to my lossless files). Life is too short for that. Go with lossless and just save yourself the trouble...at least for archiving and home use.
Secondly, the issue of space vs encoding on portables will always be at issue on small drives. If you determined that 320kbps is your cutoff point on the sampe tracks you used for testing, you would still have to decide if you are willing to trade that space for quality.
I listen to my Creative player with a combination of Rhapsody (160kbps) or Yahoo (192kbps) songs. It is not necessary for me to know if they sound similar to lossless because I do not own them on CD....
"Ignorance is bliss" does not apply to lossless encoding (which is the benchmark). It only applies to comparing something of lesser quality to the benchmark. In other words, if I drive a Ferrari (using it as a benchmark for performance in this situation) and do not test it against a car built from Ferrari scraps, I am not ignorant to the situation. I just have no reason to test them because I already have the benchmark and can live with it. If, on the other hand, I had the car built for scraps, then I may want to test it against the Ferrari to see how it performs.
