Originally Posted by Xakepa
Will repl caps, easier to read
WRONG. LOSELESS IS A WASTE OF HDD SPACE. BY NOT USING IT, I'M SAVING THE WORLD FROM WASTING RESOURCES ON 1 HDD...NO MATTER HOW LAME THAT SOUNDS, THAT'S A FACT
That's assuming used parts. With brand new parts, it would just mean leaving hundreds of GB free. A 1TB HDD will be reality likely before '07 (750GB is being made now).
GOOGLE PSYCHOACOUSTIC AND SEE WHAT BRAIN CAN AND WHAT BRAIN CAN NOT. THAT'S WHAT I MEAN |
OK...so we ignore things that are masked, pretty much. I'm not going to argue that more than maybe 5% of what I listen to (and that's a
high estimate) could not be made transparent with MP3.
IT'S BECAUSE OF INEVITABLE PRICE ONE PAYS FOR DAC-ONVERTION, AND POOR ALGORYTHMS/HARDWARE. |
What price? Yes, there are losses, but there are always losses.
90% OF ALL MUSIC CD-S MADE NOWADAY ARE SO COMPRESSED THEY OVERSHOOT 16-BIT ALL OF THE TIME. |
Yes, but that's irrelavent for the potential sound quality of a given format (also, it tends to be the clipressed stuff that needs the highest lossy bitrates...).
90% OF TIME POOR RESAMPLING LOWERS SQ RATHER THAN IMPROVING IT. |
So? Most folks don't hear the difference between 44.1 and 48. And, then using non-PC sources, there shouldn't be resampling. Anyway, what does it have to do with wanting higher rates to begin with? If it was recorded and mixed at some bit rate and depth, why not have the end result available in that depth, just as the guy that mixed it made it?
CHECK HOW MANY OF YOUR OWN RECORDINGS WOULD BENEFIT FROM LOSELESS. THAN ARGUE WITH THE FACT. |
First, you are changing your argument and premise. Here are some things that are not necessarily related:
1. That one recording sounds good as 128k MP3 (varies by recording).
2. That one recording with all information intact (lossless) sounds worse (100x, specifically) than another recording as 128k MP3 (varies by both recordings).
3. Whether a given recording will benefit from loessless archiving (usually not dependent on SQ).
FI: Scar Tissue sounding like crap in FLAC, and One Bourbon, One Scoth, One Beer being tranpsarent at 128k MP3 (LJH's, of course), does not provide any evidence for or against the use of lossy compression.
Second,
all of my recordings benefit from lossless, because using lossless is about good archiving and flexibility for the overwhelming majority of music, not percieved sound quality (it's directly for SQ on a very small selection). Fact to argue with: I recently dusted off a rack of CDs. They got that must dust, because I have not needed to remove them to listen to anything on them, nor to format-shift the music with the original as the source. That's a primary advantage of lossless archiving.
WILL YOU PLS REMIND ME WHEN? OR YOU'LL FLASH THE INFLATION BANNER BLAH BLAH |
1973
1990
Right now (and it will likely go up gradually in the future, as the search and extraction expenses keep rising). Inflation is a major problem, but not one directly tied to energy costs.
YOU'RE NOT GETTING THE POINT. THE FACT THAT SOMETHING IS CHEAP DOESN'T MEAN WE SHOULD USE IT RECKLESSLY! PLS, THINK ON THAT. |
No thing should be used recklessly, even if it costs nothing. I do not think losslessly archiving music is a reckless use of my time, money, equipment, or electricity. I think re-ripping for the sixth time (yes, I got to 6 with The Final Cut
), however, is a very reckless use of a CD, CDROM drive, electricity, and my time.
Caps weren't meant to be shouting. Just pls think |
I do. Being a philosopher causes thinking.
