illram
- Nov 24, 2016
Yes the E10K or the Fulla (1 or 2) are enough to get it plenty loud. It's just a math question.
Would definitely recommend a headphone amp for those headphones. They need a good bit of power to get the full potential out of them.
Check out the fiio e12
I had the E-12 Mont Blanc before and did not have any high impedance headphones but did have the HE-400's and Mr Speakers Alpha Dogs but fairly hard to drive and the E-12 would push them to ear bleed levels plus the bass boost was a nice feature when you wanted to have a little fun.saw this recommendation from @Mr Head P Hones on another thread, just want to get 2nd opinion, as Fiio E12 Mont Blanc is currently at $104 on amazon n might be even cheaper on ebay, is it good enough for HE 400i and DT990 pro 250?
As much as i would love to own Fulla-2 but i cant buy from their site directly only amazon will work for me n its not available on amazon ... so will this also serve the purpose? kinda fit well inside my budget
and is this amp+dac good for something?
[COLOR=0066C0]Micca OriGen+ High Resolution USB DAC and Preamplifier - 24-Bit/192kHz PCM and 64x DSD[/COLOR]
You might look at the A-5 as it is the new version of the E-12 with a lower noise floor like the E-12a but with the power of the E-12.
Not if your going out of the MacBook .but wait i would still need a dac with E12/A5 isnt it? its just an amp ...
Take a look at the Micca OriGen+ if you are only able to order from amazon. It's $110.
I have been looking at this (Micca Origen+) for months now but this review ...
http://www.verumsonus.com/micca-origen-mini-review/
I don't know how it will function with HE400i ... But it looks amazing has tons of power n all, but I don't know how good is it's DAC ...
Sent from WestWorld 2.0
