Top Mall-Fi poster. The T in META42. Formerly with Tangentsoft Parts Store
If your meter has a diode tester, just check between each pair of adjacent pads, swapping leads as necessary. Check resistance, too, with no power source connected. You should get infinite resistance and something like 0.7 V between each pin pair. If not, it isn't a diode bridge any more.
I plugged the power cable in to try and measure the things you guys measured and the TREAD lights up.
I haven't even touched anything since last night when I posted this so I'm really confused. Everything measures properly, 33 VDC unregulated and 28 VDC regulated.
Sorry, I'm just running into all kinds of problems, looks to be one thing and then it's something else, and I go and post without double checking things first! The TREAD is working all fine now.
