leftshoe
- Feb 4, 2005
I'm measuring 400mv from the ground to the output headphone jack on both channels with no source plugged in. The input channels on the op amp are both recieving around 35mv, so at least the 11 gain is working...
When I measure the voltage at the input jack, it get around 3 mv or less, so Something must be happening to the signal between there and the chip.
I'll post photos of the board if needed.
Powersupply is splitting the voltage correctly, so that isn't the problem. Op-amp is likewise recieving the correct voltage on its voltage pins. I think it may be that the cheap op amp chip I'm using may be buggered. I'm using a LM833n for now, I've already ordered one of the bur-brown chips, I should get it in a couple of days. I think I may be using the wrong sort of caps for the C2 from tangents layout, I had to get them from the local radio-shack type store(dick smith) here in Australia, so I think they might just be poor quality.
I've done a fair amount of soldering before, but I've never had a problem this annoying
