Don't know what wierd soundcards you have over there, but I personally yet have to hear one of my soundcards working at full volume level |
I'm sitting here at work with all levels maxed into a DIY amp and get no distortion at all. No distortion on any of the 200+ albums I have ripped to my hard drive. Are you sure you are using the line-out and not the headphone jack? It is not normal to get distortion from your soundcard's line-out even at max levels, which are a paltry 1V RMS. On the 4 soundcards I've used in the last 2 years (2 SBLive, 1 TBSC, 1 built-in-to-motherboard) I've never got distortion from the line-out at max levels. Just to be very clear, you are hooking your amp directly to the line-out of the soundcard and you have all eq settings turned off, both for the soundcard and for the winamp/media player, right?
I got my treble at 70% and my bass at 85% since I can't stand the sound otherwise |
If this is still true then there is your distortion at max levels. Don't blame your soundcard for distortion if this is how you are listening to music. Soundcards shouldn't be blamed for user error.
There's just some music which I know from various speaker systems as very bass heavy. Some of these tracks seems to totally lack all bottom end on my setup. Wierd |
Not weird if your speaker systems also have the bass knob cranked like your soundcard does.
The HD600 with the right amp and cables has bass very close to the best speaker systems I've heard, though still lacking at the very bottom end. Unfortunately the Corda is not that right amp, but it brings me close enough for now. If the HD600/Corda doesn't bring you close enough to what you want without a lot of eq then I would suggest looking at other headphones rather than upgrading your source and amp.
I was a bass head, I thought. When I first started with Head-Fi I was on a quest to get some bass for my HD600's.
My discovery that the HD600's are bass capable is threefold...
[good advice snipped] |
Sure, that will get you great, accurate bass, but it won't get you that booming thumping bass that typical consumers have come to know and love in their lo-fi gear with its ultra-mega-bass settings.
It astounds me how much the other guys here at work can tolerate all of that super muddy boomy distorted bass they submit themselves to in their cars and at their desks with their bass knobs and megabass switches. Most have no idea what deep bass even sounds like, they think mid/upper bass eq'd at +20db is real bass.
A better solution if you'd like to add more bass would probably be Meier's Analoguer with bass boost circuit, but I haven't tried it myself. There are some explanations of how that works on HeadWize along with some sample wavs to give you an idea. |
You could just build one level of the bass boost circuit with 3-4 resistors, one capacitor, and one opamp per channel. You'd need a PS too, but even with nice opamps your looking at under $50 for the parts. Also, I'm pretty sure that this sort of circuit can easily be added to the META42, especially if the resistors are socketed. You just replace one resistor in each channel with two resistors and a capacitor. Very easy to do and you can set the frequency and amount of bass boost by just choosing the right cap/resistor values. The .wavs you talk about are for the complicated bassenhancer project though, not the simpler bass boost which is built into the Analoguer.
