TwizzyTonkaa
I just ordered the Cosmos I will have to upgrade my amp and dac eventually probably
Is Cosmo a big enough upgrade to justify purchasing if I already have Venus? (with the pad upgrade to Cosmo, of course)
Hi.
The answer is yes.
At equal magnet forces, if we consider that the mass of the Cosmo's planar membrane wich integrates the mass of the Cosmo's plastic film (0.5 um thick versus 2 um for the Venus) and the mass of the pure silver metallic traces covering respectively 90% and 80% of the surface of the planar membrane of the Cosmo and Venus (silver tracks of 0.1 um thick (calculated) for the Cosmo versus 1.26 um (calculated) for the Venus); well, the calculated mass of the Cosmo's mobile crew is 8.26 times lower than the Venus's mobile mass (and a very close,1.22 times, at the estimated mass of the Susvara OG's mobile equipment).
Source and calculation details here :https://www.head-fi.org/threads/moo...-size-discussion.970569/page-27#post-18103837
And the lower the moving mass, the more agile, faster and finer the membrane is at bringing out the slightest sonic detail (in particular the microdynamics).
The Cosmo is more detailed, more precise and finer than the Venus, and it shows (heard).
The pads will play on the tone.
Indeed, the Cosmo's stock pads are quite colorful, which pleased Résolve (here: ) ; but there are much more neutral pads for the Cosmo, such as the EP-100A pads (not microperforated inside); the Para's hybrid pads (microperforated inside) (even more neutral than the EP-100A pads) and of course other pads, such as those proposed by @Groundhog here : https://www.head-fi.org/threads/moo...-size-discussion.970569/page-35#post-18344882 or the Brainwavz hybrid XL pads proposed by @N3urolink
(Nb: these Brainwavz hybrid XL pads (microperforated inside like the Para's hybrid pads) will soon be tested by the author Sai of the latest Cosmo review (see the discussion at the end of the article here : https://unheardlab.com/2024/09/21/review-of-moondrop-cosmo-true-flagship-yet/).
Ah, the bass was the one thing I was hoping might be improved on the Cosmo. So much for that idea.Cosmo are really good headphones for it's price but they are not as good as Venus in my opinion. I was very eager to buy Cosmo. For a first time I was looking forward for first reviews nad I even wanted to order them from Amazon as soon as they appeared. I hold my horses and a month later I was able to borrow them. I knew I wanted to buy them, but after comparing them with Venus I really didn't see a point.
Venus IMHO are just better.
They have better extension than Cosmo. Bass on the Venus is spectacular, much better than Cosmo. Treble on Venus has a proper spark. On cosmo it's just muted in comparision. Cosmo in my opinion had a bit better soundstage depth but that's not enough to buy them. Of course if somene is looking for more universal sound, Cosmo might be a better choice. For me they lack emotions which a find in Venus.
Much will depend on a source chain. I have 12W/32Ohm Class A amplifier and quite decent other parts of my chain (nothing extremely expensive but I guess just fine). I use only silver interconnectors and headphones cables to achieve maximum transparency to the sound and maximun neutrality and smoothness. Venus scales like crazy with better gear. On my gear they sound very good but I heared them on my friend's top high- end equipement and I was blown away.
They are surely one of the best headphones on the market.
Of course I also borrowed Moondrop Para just to check it's pads on Cosmo. They indeed sound a bit better. They have more bass but it's quality is still behind Venus.
Pads from Para have very little space for ears and they are very uncomfortable. I wasn't even considering using them. If I had another pads for Cosmo, they might change my perspective.
My Summery: Don't change your Venus to Cosmo if you don't check them first. I would never do it. My 2 friends who were comparing Venus to Cosmo came to the same conclusion as me.
By the way. Moondrop Para are much worse than Venus and Cosmo.
I found it extremely good sounding even on my mid-fi amp / dac comboWell, I ordered a Cosmo at the discount price, so I will soon find out for myself.
