I'm relieved the ZMF pads made such difference to your Cosmo and KO your collection. seems this combo can be endgame for some audiophiles looking for this kind of sound for such a low price as well.....
I always listen to anime songs, and I have yet to encounter headphones that portray female vocals more beautifully than the COSMO.
Unless a headphone in the same price range surpasses the COSMO, I won't be letting go of mine.
(Except for MOONDROP's electrostatic headphone, the MOONZERO, of course.)
Hello everyone.
Hello to
@N3urolink and
@Fatdoi, the proud owners of the COSMO (and many other headphones).
For
@N3urolink
I'm not sure that Moondrop's electrostatic headphones MOONZERO, announced several years ago at a price of US$1,000, will ever be released; it seems to me to be a stillborn project.
It was heavy, using the VENUS headband which, in addition to being heavy and moderately comfortable, is fragile in its attachment. The FR curve of the MOONZERO's day could be improved, and, a major handicap (unlike the planar and electrodynamic headphones), it requires the use of a good amplifier specifically for electrostatic headphones, which can quickly drive up the bill if you opt for a high-performance e-stat amplifier like the KGSSHV CARBON.
I think the COSMO planar headphone will remain Moondrop's flagship full-size open headphone for some time to come, especially if fitted with the excellent ZMF lambskin perforated pads recommended by
@Fatdoi.
On the subject of the COSMO equipped with ZMF Universe Lambskin perforated pads, I did a manual sine sweeps (between 20 Hz and 10 KHz; above 10 KHz, at my age, my hearing is impaired) and comparison with the same COSMO equipped with the Para's hybrid pads, knowing that the COSMO's FR is known with the Para's hybrid pads.
To cut a long story short, with the Para's hybrid pads, the COSMO has a very linear FR between 20 Hz and 10 KHz (at +/-3 dB), with progressive attenuation in the sub-bass, below 50 Hz, a small frequency dip (1 to 2 dB) around 2 KHz, a frequency peak of around 3 dB (at 3 KHz) and a frequency dip of around 3 dB (around 6 KHz).
With the ZMF pads (Lambskin perforated), the sub-bass at 25 Hz and 31 Hz of the COSMO is well present (as much as with the Para's hybrid pads); 40 and 50 Hz are slightly attenuated compared with 60-80 Hz (note: I think the Brainwavz pads are more bassy at 40-50 Hz, but less punchy in the bass than with the ZMF Lambskin perforated pads).
The good news is that, as with Para's hybrid pads, at manual sine sweeps, there's no significant level hump SPL between 800 and 1250 Hz (compared with the 600 Hz and 1600 Hz) with the ZMF pads, which explains why female vocals aren't shouty (unlike, for example, with the Stax SR-009).
As with the Para's hybrid pads, there's, with the ZMF pads equipping the COSMO, a slight attenuation (1 to 2 dB SPL?) around 2 kHz, but we don't find the level hump (of about 3 dB SPL) at 3 KHz that we find with the Para's hybrid pads; on the other hand, there's with the ZMF pads a small peak (+ 2 dB SPL?) around 5 kHz, and a small trough (- 2 dB SPL?) around 4 KHz.
The other good news is that, in addition to the smoothing out of the frequency hump (of 3 dB SPL) at 3 KHz, hump found with the Para's hybrid pads, but not longer with the ZMF Lambskin perforated pads ; well, the ZMF pads also give more treble to the COSMO, around 6-8 KHz, compared to the same COSMO fitted with the Para's hybrid pads, giving it all the brilliance it lacked when equipped with Para's hybrid pads or Brainwavz XL hybrid pads.
All in all, I think that the FR of the COSMO equipped with these ZMF (Universe Lambskin perforated) pads is excellent, both for producing deep bass and sub-bass (nb: the 25 and 31 Hz are well present), with punch (dynamics) for the bass and mid-bass (and also the snare drum); the midrange and upper-midrange are almost perfect, with voices reproduced sublimely, without harshness, but also without attenuation (the voices are well present, not recessed); the FR is not V-shaped (as with the VENUS), so everything is better balanced; highs are also superb, well extended, not attenuated between 6 and 8 KHz (unlike the COSMO fitted with the Para's hybrid pads and Brainwavz XL hybrid pads); brass and strings (violins) are superb to listen to (with ZMF pads), without excess (no tensing or auditory fatigue), without sibilance (for voices), but with superb finesse and extension.
For
@Fatdoi, Japanese Koto's music instrument transcription of this Chaconne by J.S. Bach is indeed superb to listen to, in particular with the COSMO equipped with the ZMF pads ; you hear everything, really everything, and in particular all the fine and subtle harmonics of the strings of this Japanese stringed instrument that I didn't know.
Coming back to the price of the COSMO: 899 US dollars + around 80 to 100 dollars worth of ZMF (Universe Lambskin perforated) upgrade pads, it's seem to me hard to beat that, even with headphones costing 3, 4, 5, and even 6 times as much! Food for thought ...
EDIT:
Manual sine sweeps on headphones aren't exactly sexy; you do them once, and even several times in a row (it's tedious to do) to characterize the FRs of the pads being compared (Para's hybrid pads and ZMF Lambskin perforated pads used with the COSMO), then you swear never to do them again; it's a pain and demanding to do, especially following a false maneuver on the test CD when white noise is heard in the ears at high SPL (a very unpleasant experience).
To forget this morning's test, I enjoyed listening this evening to some real music with my COSMO equipped with these excellent ZMF pads, by listening to this video (below), pleasant and fun to watch, and well recorded.
The COSMO headphones fitted with the ZMF pads enhance the female singer's voice very well (what a voice!), as well as the accompanying instruments in the background, also very well reproduced; a pure moment of pleasure of listening through headphones and relaxation, before going to bed.
