- Feb 1, 2011
Silver Dragon V1 IEM FitEar Upgrade
Headphone Cable
$185.00 USD
Moon Audio Silver Dragon V1 IEM Headphone Cable for FitEar In Ear Monitors
Moon Audio Silver Dragon V1 IEM Possible Connection Options In Order from L to R-
Furutech XLR, RSA balanced, iBasso, 4pin mini XLR, Oyaide Str. Mini, Oyaide Rt. Mini, Stock Mini
Positive Feedback Online Writer's Choice Award Winner - December 2012
Headphone Cable
$185.00 USD
*Positive Feedback Writer's Choice Winner*
The Silver Dragon V1 IEM headphone cable is the baby brother to the Silver Dragon Headphone cable.
We have designed it for use with FitEar Custom In Ear monitors or IEM's where light weight and flexibility are a must! No flimsy or stiff cables are made here at Moon Audio.
This custom iem headphone cable will open up your Custom In Ear Monitor's and let them breathe easier.
It provides a more musical presentation and sound stage depth. You will hear more clarity, instrumentation and musicality.
Throw out that cheap stock cable and bring your Custom IEM's here to Moon Audio!!
"The Silver Dragon JH3A Cable and Silver Dragon IEM Cable gives a +3db increase in input sensitivity across the entire frequency range and much greater detail than any other cable."
Jerry Harvey, JH Audio, RMAF 2012
"Moon Audio's Silver Dragon line, specifically their IEM and LOD cables, are an essential component of my portable audio rigs. I use the IEM cables with my JH Audio JH-13 Pros, my reference (a sonic marriage made in heaven by the way) and the LOD cable on my iPod Classic and iPad2. I'd love to take credit for discovering these fantastic cables, but I have Jerry Harvey of JH Audio to thank for that. Now, when the founder and lead designer of your favorite IEM tells you to check out a particular set of cables, saying they enhance the performance of his product, it's advisable to follow his instructions.
If making deep connections with your music is important...products like the Silver Dragon cables can act as a conduit to that grand connection. I'm never giving mine up, and I recommend you check 'em out if personal audio is part of your listening experience." Michael Mercer, Positive Feedback, Issue 64, November/December 2012
Description
This cable has specific connections for the FitEar in ear monitors or iem's.
The Silver Dragon IEM is a coaxial design using a 99.99998% UP-OCC Stranded Silver 26AWG center conductor for the positive leg. The center conductor uses the same Kevlar reinforcing as the other Dragon cables. The center conductor is wrapped concentrically by a 99.99998% UP-OCC silver plated single crystallized UP-OCC pure copper stranded 26AWG gauge conductor with 7N purity 99.99998%. Now that is a mouth full
The left and right signal cables run parallel to each other resulting in a very low inductance. Both signal jackets are polyethylene and the cable is extremely flexible yet very resilient and resistant to flex failure.
A variety of connection options are available for your downstream connection such as the mini plug, RCA, XLR and many others.
We custom build these in house to your connection specification. The cable can be used in either a single ended or balanced design. The wire is soldered to a connector using high quality Cardas silver solder.
Connection Arrangement
Red is Right Channel
Blue is Left Channel
Dots always should be pointing in upward direction.
"Drew, I just wanted to tell you how pleased I am with this cable on my new Freqphase JH Audio 13's. The improvement to the clarity of these new phones was only magnified by this cable.
It did so without altering the tonal balance, and added a sense of refinement to the sound.
They are not floppy flexible like some others but they are perfectly manageable and don't tangle or spring back at you when coiled like other cables I've tried.
Well done. "(Posted on 12/6/12) Todd R.
Drew Baird, P.E.
Moon Audio
Moon Audio
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
