- Mar 29, 2003
As an engineer, I know the importance of going green. It has been drilled into the engineering community for the last 5 yrs religiously. So we have started to do our part and will start adding new and exciting Green Audio components to our website as they become available. The first to walk in the door is the new Monster GreenPower HDP 900G PowerCenter. I have replaced just about every power strip in Moon Audio and in the rest of my Home with these. I like the fact is has a power clamping or true off position on half of the outlets. So that when you turn off what is plugged into it it gets a true power off position. No more Stand-By Off which continues to draw power from your outlet.
I welcome any comments on products you have found that help save energy resources in your home. But lets try to keep the topic with in the electrical product base platform. Or the thread could go out of control
Here are the details:
[size=medium]Monster GreenPower HDP 900G PowerCenter[/size]
[size=small]Retail $149.95 Your Price$Call[/size]
Highly Recommended!!!
[size=small]Super Hot Product!!!! [/size][size=small]Go Green!!!![/size]
[size=x-small][/size]
[size=x-small]FEATURES [/size]
[size=x-small]• Monster GreenPower™ stops standby mode energy waste and saves money [/size]
[size=x-small]• Exclusive Dual Mode Plus™ automatically disconnects and sounds an alarm to protect your equipment [/size]
[size=x-small]• Patented HD Clean Power™ Stage 1 filtering rejects noise and interference [/size]
[size=x-small]• Surge protected coax, phone, and network connections [/size]
[size=x-small]• 8 surge protected, color-coded AC power outlets [/size]
[size=x-small]
[/size]
[size=x-small]Keeps All Your AV Equipment Safe with Advanced Dual Mode Plus™Surge Protection[/size]
[size=x-small]Common surges and spikes can easily damage or destroy the delicate circuitry in your AV equipment. The HDP 900G PowerCenter™ provides the advanced protection you need to keep all your valuable equipment protected against even the most powerful surges.[/size]
[size=x-small]Exclusive Dual Mode Plus automatically disconnects to isolate your equipment from harmful surges and spikes. It also sounds an alarm to let you know that the PowerCenter has protected your electronics from dangerous power conditions.[/size]
[size=x-small]Complete Protection for All Connections[/size]
[size=x-small]All of a component’s inputs and outlets need to be protected, or the entire system will be vulnerable. Dangerous surges and spikes can travel on your coax connections to damage your AV equipment. The Monster HDP 900G features comprehensive protection with coax, phone, and network connections to keep all your connected equipment safe.[/size]
[size=x-small]Electrical Noise and Interference Can Reduce the Lifespan of Your AV Electronics[/size]
[size=x-small]Your home’s electricity is full of noise and interference caused by all of your appliances and electronics: cell phones, computers, even your lights, all contribute to the problem. This "dirty power" stresses the delicate digital circuitry inside HDTVs and other home theater equipment, reducing their performance and potentially shortening their lives. However, ordinary surge protectors can’t remove the effects of dirty power.[/size]
[size=x-small]Patented HD Clean Power® Removes Noise and Interference to Protect Your AV Equipment and Maximize Performance[/size]
[size=x-small]The HDP 900G features patented HD Clean Power filtering that is precision-engineered to remove electrical noise and interference. This protects the delicate circuitry inside your HDTV and other electronics from unnecessary wear.[/size]
[size=x-small]HD Clean Power maximizes your equipment’s lifespan and ensures the best possible picture and sound performance.[/size]
[size=x-small]
Automatically Save Money and Reduce Energy Waste with Monster GreenPower™[/size]
[size=x-small]Your DVD player, HDTV and other electronics continue to use power even after you’ve turned them off, wasting energy in stand-by mode. Monster GreenPower™ eliminates energy waste and saves money by automatically switching off outlets.[/size]
[size=x-small]Simply plug your TV or AV receiver into the 900G’s GreenPower Control outlet and plug your other AV equipment into the GreenPower switched outlets.[/size]
[size=x-small]Whenever you turn off your HDTV or AV receiver, the GreenPower switched outlets automatically switch off to eliminate unnecessary electricity waste by your DVD player, subwoofer and other equipment. When you turn your HDTV back on, the GreenPower outlets automatically switch on again so the rest of your equipment is powered up and ready to use. [/size]
[size=x-small]Even better, GreenPower automatic outlet switching makes it easy and convenient to save energy and money without having to manually switch off individual components. [/size]
[size=x-small]Powerline™ Network Compatible[/size]
[size=x-small]Powerline Communication,™ also known as HomePlug® , is a revolutionary home network system that works on your home’s existing electrical wiring. Ordinary surge protectors can block PLC signals, but the Monster MDP 900G is engineered to allow full-speed PLC network communications.[/size]
[size=x-small]
[size=x-small]
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
