Monoprice Monolith Liquid Platinum - By Alex Cavalli
Nov 5, 2019 at 12:07 PM Post #2,371 of 5,150
Power cable recommendation? Hadn't even thought about the ability to replace that. Slowing upgrading my power cables and moving to linear power supplies where possible, so curious what you went with.
I grabbed a used Audioquest NRG-2.
Nov 5, 2019 at 1:00 PM Post #2,372 of 5,150
Nov 5, 2019 at 1:28 PM Post #2,373 of 5,150
How does it compare to WireWorld power cables?
I haven’t tried their 2-prong power cables, but overall, I’ve found WireWorld cables make a larger order-of-magnitude improvement, and comparing 3-prong cables WW was a bigger improvement.
Nov 5, 2019 at 2:22 PM Post #2,374 of 5,150
Thanks Dave - totally missed the 2 vs. 3 prong cable... <embarrassed>
Nov 6, 2019 at 10:32 PM Post #2,375 of 5,150
Hi Dave: I have a different question. Do you know whether there are reviews of the upcoming Liquid Gold X out there in the wild yet? To be perfectly candid, this is also another way of asking whether you're planning a review of the unit as you did for the platinum and the Spark.
I would really like to know how different the Gold X sounds from te platinum so that I can make an informed decision as to whether to plan an early purchase of the x or just hold on to my LP for more further use.;;
Nov 6, 2019 at 11:06 PM Post #2,376 of 5,150
I want to know more about Monoprice new Liquid Platinum with AKM 4499 than the new Liquid Gold X with AKM 4493. Pairing the new LP with their THX 887 is cheaper than a new Liquid Gold X.
Nov 7, 2019 at 11:57 AM Post #2,379 of 5,150
Nov 8, 2019 at 2:01 PM Post #2,380 of 5,150
I'd love to review it. I need to catch up with @runeight
Nov 8, 2019 at 2:26 PM Post #2,381 of 5,150
Nov 9, 2019 at 3:03 AM Post #2,382 of 5,150
I just bought a LP. Many recommend using it with a preamp. Any issues with double amping? I temporary left the headphone game. I miss it so I bought a pair of HD800. I don't have a DAC yet only a Naim Uniti Atom which is driving speakers. The Atom has preamp outputs though.
Nov 9, 2019 at 9:42 AM Post #2,383 of 5,150
I haven't had any problem setting my LP to about 50% on the dial and controlling the volume via my preamp, that setup should work great for you as long as the preamp outputs on the Atom are not fixed.
Nov 9, 2019 at 11:54 AM Post #2,384 of 5,150
Cool. I'm going to try it first. Naim never release specs on the preamp section. Most use it with poweramps for speakers, but I assume it's not a fixed preamp.
Nov 12, 2019 at 6:12 PM Post #2,385 of 5,150
