Monarch MKII replacement cable recommendations
Aug 3, 2022 at 5:01 PM Thread Starter Post #1 of 8
Luke-
UK
I’m not getting on with the stock cable I’m looking at keeping the same sound characteristic. I’m want a cable that’s light weight and very supple and good quality and modular
Recommendations please around the £200
Aug 4, 2022 at 12:06 AM Post #2 of 8
You can try Brise STR7, i think its good
Aug 4, 2022 at 7:38 AM Post #3 of 8
The brise is like the triple more expensive than required :scream:
As you live in UK why not look at toxic cables or cosmic cables?
Nov 26, 2022 at 11:51 PM Post #8 of 8
Thanks I will check it out
Did you end up getting these? Just curious because I too don't like the weight and stiffness of the stock cable
