opero
- Feb 3, 2017
Hi i have a new Mojo from Chord, I would like to use it through my MacBook Pro, even I know it was not built for that at the beginning. The problem is I'm so scared to loose my ears if there is a sound I didn't expected (by example a tweet notification, etc.) pops out, because the Mojo can push a lot the volume (I also have to turn almost as mute the sound volume of my music program..).
So i fund a music player named "Fidelia" from Audiofile Engineering which allows me to control better the sound volume, but I'm still stuck with this eventual volume pic. Do you know if there is a program which has the utility to be a sort of sound limiter (mute sound if it goes too high), installed directly on my MacBook Pro ?
I do close my wifi and all programs in order to prevent a high sound problem, but I'm still not satisfied. The mojo is only on the input of my computer, as DAC and amp.
Thanks
(sorry for my English, I'm French)
Adrien
Thanks
Adrien
