Modi 3 connection help, please...
I have a blu-ray player which plays blu-ray AUDIO discs well, but only has a HDMI out jack (female), no other output port.
How can connect my Modi 3 to this blu-ray players HDMI port ?
Would an "audio extractor" box work ? (HDMI in to coaxial audio out). Since the ones I've seen also have analog outputs, there is a really cheap DAC inside. If going HDMI in & Coaxial out, would that bypass the cheap internal DAC, just to use this box as an adapter to connect cables ? If it does not bypass the internal DAC, and the cheap DAC is active, it seems a bad idea to run that audio signal into MODI 3 then ?
I did find an audio extractor box, gofanco HDAudExt, Amazon $65, with a 3 way switch - EDID (for video display I think), Bitstream audio output, or PCM settings. In Bitstream mode there is no audio output to the analog connectors (maybe bypassing internal DAC). If the bitstream signal is not decoded yet from the blu-ray & using the box coaxial output to pass into the Modi 3 coaxial input, will the Modi 3 decode the blu-ray audio signal ? The final gear in chain is an analog not digital receiver, so the receiver won't decode the signal.
I think Bitstream delivers a better sound thru coaxial outputs than PCM does, not sure. On the PCM extractor box setting, analog audio output goes to all connectors so cheap internal DAC must be active in PCM mode for this box.
https://www.gofanco.com/products/audio/hdmi-2-0-repeater-with-audio-extraction-hdaudext.html
link to gofanco unit from their site, the diagrams & fotos help a lot.
also pdf of owners manual below.
The coaxial audio output of gofanco seems to suggest 5.1 channel audio only, but 2 channel audio should output fine ?
The Modi 3 analog outputs would run into a vintage 2 channel hifi receiver.
Or is there a better way using something else ?
