tourmaline
- Nov 10, 2003
Hold the phone Stuart,
i thought the guy spoke about welwyn wirewound resistors used to replace the 4 in parallel. You know the big brown ones near the mosfets and the one in the powersection. I forgot the name, but i think these are the same you are going to try out. But he was speaking of higher wattages though........
Well, you can read the value of the big resistors on the pictures. I cannot find anything on the black resistors used near the tubes though.
I'll get back to ya.
you can't use elna's; they are getting scarse and expensive and they wouldn't fit in anyway, he told me. They have only very few left and they would be too big in that place. 1 elna cerafine 100ufarads is 130 euro's.
As i said before, i changed the signal wires for audio note silver signal wire! I put shrinkrap over it so it has basically some protection and air dielectric, wich is superier to anything else.
According to them, it's the best for signal wiring amps. They use it for all their mods! 20 strands of very fine pure silver. A very thin wire.
I suggest Stuart, you take a look at the pictures again and you see the large scale of modification. Everything has been tackled. The signal wire, i allready did myself and was during stage one of modification.
Stuart,
that's one of the reasons i choose the vcap oimp caps, since they have very tight, articulate yet full bass.
As a matter afact, i don't like using earth at all. This is one of the reasons you have those loops etc that smear the sound.
Originally Posted by Black Stuart /img/forum/go_quote.gif WHOOPS, renag, renag - I got it wrong and no I had'nt been imbibing or doing anything else. The sig/wire is solid core copper, probably 0.7mm/21AWG or thereabouts. Also there is no sheilding on the incoming sig/wire. I would'nt have known if I had'nt cut away the heatshrink on one end.This for me is good news as I don't like sheilding per se on signal wire anyway. I have no idea how good this copper wire is or is'nt. I shall be replacing this and the wire from the pot to PCB with mil. spec. s/plated solid core copper - this is a personal choice and others may well differ. This also means that you can replicate the wire configuration of your favourite I/C inside the amp, the outer red sheath is worth keeping and may have been used to sheild the sig/wires from vibration within the amp as well as protecting them from heat. I don't know if Tourmaline has replaced any of this sig/wire or not. I suggest if you are going to change this, do so before changing caps - there is no need to lift out the PCB to effect this. So for those who are thinking of modding the Bada do think carefully about all the sig/wire, changing this wire is no big deal. I don't like the RCA sockets and using the plug body to solder the return wires to is not a good idea, much better is a dedicated earth tag, which the s/plated plugs I am replacing them with has. Tourmaline - if this shop you used for the mods will not tell you the resistor values just use an online resistor chart to determine these and get back to us. Personally if I paid serious money for these mods, I would insist on them telling me the values ( it's called making them an offer they can't refuse). The resistor replacing the set of 4 next to the mosfets should be easy to read, it's almost certainly available from RS. I'm particularly interested in resistor values if they have been changed around the valves. I will report back when I have changed the wiring. Don't forget that shunting the pot is so simple and you can experiment to your heart's content with resistor types - I am going to try some Welwyn 1% 1/4W today but many may rec. Vishay bulk foil - big wattage is'nt important here, most stepped att. are built using 1/4W. |
Stuart,
