Magsy
- Nov 9, 2004
There you are
Check the offset by sticking the multimeter probes on the output of each channel and ground, play some music. Measure for DC at the highest sensitivity setting on the meter. Check both channels this way.
People will have differing opinions on what is a safe level
My first 0404 had about 2mv + 2mv with the LT1364, with an AD8620 I had 0.5mv + 0.8mv. My current 0404 is not so good, maybe because I have two browndogs in the link or lesser opamp, this one produces 5mv + 7mv. I was unsure at first, but I have run it like this for a year with an amp not equipped with DC blocking caps and there are no ill effects.
You should be ok under 5mv I think..anything under 2-3mv I wouldn't worry about. Try mesuring the output of some good and bad branded kit, I've seen a few things with a lot of offset.
If you run an amp with DC blocking caps later in the chain then you have no need to worry.
Obviously to be completely safe you should be at 0 and the only way there is with the caps in.
Don't rush with the cap changes, unless you are changing the output ones I doubt you'll hear much difference.
