Ok, here's the start of the new clock install (micro-surgery is fun
- First pic is crystal removed with the smd Crystek clock beside it
- Second pic is the back of the smd clock with a small board cut from a matrix board - I had put solder on the clock pads as I had intended to solder to the board but I didn't use this method - instead I did this:
- Third pic - there are little grooves from the pads that go up the sides of the smd clock - here is a component lead cut-off soldered in the groove.
- I did this with all 4 pins (although I don't need pin 1 connected) & put the pins through the board from the top so I could solder the pins underneath to the copper side of the matrix off-cut board.
- Pic 4 - This gives a very solid & small structure. I soldered the out pin to the Xtalin (pin 12) where the original crystal had been.
- As a quick & dirty job I soldered the clock VDD to the 3.3V regulator Vout that goes to the Cypress USB chip; the clock gnd pin to the USB gnd at the USB socket.
Ok, I see the size limit for jpg is 97K - mine are > 100K - I'll have to see what I can do! I posted this message & the pics here:
http://www.diyaudio.com/forums/digit...ml#post1973535
- Plugged in USB cable but unit is now not recognised by the laptop
. Not surprising really as I haven't changed the load cap that was on the crystal (I told you this was quick & dirty to see if I could get it working straight off
). The other issue that may be causing it not to properly initialise is that there is a timing condition that an external clock has to meet for the Cypress to operate correctly. I will probably try to power the clock from a 3.3V battery as I originally intended & have this powered up before the Cypress chip.
