soloz2
- Jun 30, 2006
Yes, the Auzen goes one step further and is DDL capable
Originally Posted by Gautama /img/forum/go_quote.gif X-Fi has SPDIF via coax cable from the flexijack right? |
Originally Posted by Thrillo /img/forum/go_quote.gif The XtremeMusic doesn't, but the more expensive models do. The XtremeMusic only has optical-out. |
Originally Posted by Bones13 /img/forum/go_quote.gif Aye, best of both worlds IF you want to do multichannel EAX for gaming. If you leave the XFi in SPDIF mode through your DAC full time (non directional EAX sounds are awesome this way) then any SPDIF device works fine for "audiophile" listening only. The real magic of using an XFi is to swap the mode from a gaming to audio-creation, and have a multi-channel speaker set up for gaming, and a nice DAC/AMP/headphone set up for listening to music. I don't use EAX for gaming, so I have skipped the EAX/multichannel setup. |
Originally Posted by hadouken /img/forum/go_quote.gif One thing you should be aware of is that I dont think EAX is transported over S/PDIF using Vista drivers, afaik this is a fault in the Auzentech software and not hardware. I might be wrong as I dont use S/PDIF but worth looking into if you wanna use EAX. |
Originally Posted by hadouken /img/forum/go_quote.gif I moved from the XtremeMusic (vanilla) to the X-Fi Prelude, it was well worth it from an audio quality point of view, I have also swapped the opamps out with the much better OPA627SM+. But with your card already having the LM4562 which is what the X-Fi prelude comes bundled with, I can see the improvement for you being negligable at best. Of course you get all the benefits of the Creative chipset such as EAX5.0 (rivals can get EAX2.0 at best seeing as Creative wont release the specs - they're great at that ![]() One thing you should be aware of is that I dont think EAX is transported over S/PDIF using Vista drivers, afaik this is a fault in the Auzentech software and not hardware. I might be wrong as I dont use S/PDIF but worth looking into if you wanna use EAX. Have you considered getting something like the EMU 0404 for the sound quality? A lot of the X-Fi features such as Crystalizer and CMSS can be emulated using software solutions instead. |
Originally Posted by Brando /img/forum/go_quote.gif I'm starting to think maybe a good budget amp\dac combo might be good. I was reading about the zero and the octavart and they seem nice but I'm still trying to get a handle on what really works. |
Are you talking about the card or the separate external usb one? Does the card have more output power than the usb version? |
Originally Posted by cotdt /img/forum/go_quote.gif it's a minor upgrade. a high-end external DAC would be a major upgrade. |
Originally Posted by Brando /img/forum/go_quote.gif Is there a dac\amp combo you know of that would fit the bill? I was considering that route too but I'm confused by what seem to be conflicting opinions on the subject. I'd really like to upgrade the amp and dac, I just have to be able to afford something that doesn't compromise either aspect. |
