tgx78
Member of the Trade: tgxear
![FD015A75-C58D-4E9F-9CC6-3A9E2FBC4378.jpeg FD015A75-C58D-4E9F-9CC6-3A9E2FBC4378.jpeg](https://cdn.head-fi.org/a/11416251.jpeg)
![78D39976-9E1B-429D-9153-4915BBB6EC15.jpeg 78D39976-9E1B-429D-9153-4915BBB6EC15.jpeg](https://cdn.head-fi.org/a/11416247.jpeg)
![3B32B9BE-B0AF-40E1-B2F6-51882C5770FD.jpeg 3B32B9BE-B0AF-40E1-B2F6-51882C5770FD.jpeg](https://cdn.head-fi.org/a/11416248.jpeg)
![F6BD8E02-34A2-4984-B419-994737F1F12D.jpeg F6BD8E02-34A2-4984-B419-994737F1F12D.jpeg](https://cdn.head-fi.org/a/11416249.jpeg)
For the BA10. Sound is nice and warm
![DAC0ACB5-5AB1-466F-8C74-28BD9CD4AD70.png DAC0ACB5-5AB1-466F-8C74-28BD9CD4AD70.png](https://cdn.head-fi.org/a/11416254.png)
![C0F7AA1A-6BB8-4479-A477-8BF8D9A58388.jpeg C0F7AA1A-6BB8-4479-A477-8BF8D9A58388.jpeg](https://cdn.head-fi.org/a/11416255.jpeg)
if you want more balanced sound
![Headphone Smile :) :)](https://cdn.head-fi.org/e/headfi/smily_headphones1.gif)
![FB4C9254-E8E7-40C5-B074-AA3ECF10CEB8.jpeg FB4C9254-E8E7-40C5-B074-AA3ECF10CEB8.jpeg](https://cdn.head-fi.org/a/11416257.jpeg)
![59600579-F1E0-41FF-A9CC-E9C5C5CABAF6.jpeg 59600579-F1E0-41FF-A9CC-E9C5C5CABAF6.jpeg](https://cdn.head-fi.org/a/11416262.jpeg)
Tanchjim filters added in the mix
KZ DQ6 sponge mod
This tamed the treble spikes almost ideally. Unfortunately, it made the bass bloated, with way too much mid bass and muddiness. Likely not enough airflow.
This tamed the treble spikes a little, to take the edge off, but not as much as I would like. There is enough airflow though, and the bass remains at stock tuning. While it’s not ideal, it is something, and the sound can be further tailored with different ear tips. The sponges didn’t noticeably affect technicalities, such as detail retrieval, soundstage, and imaging.
Yes. Unfortunately I don’t a variety of sponges to try right now, and I don’t have any measurement equipment, but the Moondrop filters work well. It’s a learning process for me.That means the sponge density is too high, try lower density sponge, and keep doing that way for better airflow. This kind of mods need measurement tools and trial & error method efforts, be patient!
Super easy DQ6 mod with KBEAR believe filter. Just peel and attach the KBEAR filter after removing stock dust guard.
That mod is excellent at taming the treble w/o affecting upper mids too much. Unfortunately for me, I don‘t have the hang of it yet.But I'm liking the JVC james444/Slater mod (link) the most, it's enough to tame the splashiness and the presentation at the treble is more organic overall, which is something the graph can't show.
True. I was struggling to perform this mod but using this guide and a needle helped quite a bit to achieve a good 'cylinder'.That mod is excellent at taming the treble w/o affecting upper mids too much. Unfortunately for me, I don‘t have the hang of it yet.
Moondrop filters do have the strongest dampening effect. I will try measuring it soon.Wow, nice! Definitely, I'll try it. I just got my DQ6 yesterday and even though I'm liking it a lot for instrumentals I confess that peak at the treble is a bit bothersome/harsh to me when the cymbals strike at loud-ish volumes, and perhaps that's the culprit for the slightly artificial tonality for some people.
I've been playing with mods, definitely, the tiny sponge/foam that I have here (pic) is high density and it tames the sound too much. But I'm liking the JVC james444/Slater mod (link) the most, it's enough to tame the splashiness and the presentation at the treble is more organic overall, which is something the graph can't show.
Out of curiosity, when you have some free time could you measure the moondrop filter + DQ6 using your rig? Whenever I measure it on my DIY rig (boya mic+tube) the moondrop filter shows the strongest dampening effect, so I'm not sure whether it's real or just a limitation of my DIY rig.
(the green shows the effect in just adding the filter and keeping the same volume as the stock)
Indeed. That makes sense to me but I'm just not sure about it taming even the lower-bass.Moondrop filters do have the strongest dampening effect. I will try measuring it soon.
