Mod a Headphone with non detachable cable to DETACHABLE CABLE !
Dec 18, 2012 at 4:09 PM Thread Starter Post #1 of 12
MiyuuKun
Would anyone tell me or guide me on how to mod a headphone with non-detachable cable to detachable cable .
Like this guys > http://www.head-fi.org/t/553483/ath-m50-removable-cable-mod
It would really be much more easy and increases its portability !
(I'm 15 and I dont really understand on how to mod a headphone) so please kindly help me
Dec 18, 2012 at 6:27 PM Post #2 of 12
what headphones? or better yet, just buy a headphone with a detacheable cable. not all female jacks (like neutrik) would fit inside a headphone without touching the driver.
Dec 18, 2012 at 6:35 PM Post #3 of 12
You could also do what superlux did with some of their phones, and terminate the cable with a jack one inch from the driver, and use an extension cable.
Dec 31, 2012 at 6:31 PM Post #6 of 12
weeee! looks damn nice ! Is it hard to solder and to mod it all over to the end?
It was actually really easy. I'm not even the best at soldering and I had no problems at all. There's plenty of room to solder the new wires on after cutting the old ones off the driver. Really, the part that took the longest was making the hole on the bottom wide enough to put the jack through. It only took a couple minutes of filing and went right in!
Jan 1, 2013 at 7:59 PM Post #7 of 12
Repost from the DJ100 thread.
I can go one better.
Disassembled and labelled:
Widen that hole for a 3.5mm female jack.
Solder dem wires.
Finished connections.
Put the jack in place and secure with epoxy glue.
Admire your new DJ100 with removable cables.
