h-man
- Apr 19, 2004
I don't think the wire is an option, the usual method of fixing bad ankle fractures is with a plate and screws; however, that is at the TIME OF THE FRACTURE, not when the fracture has united. Any orthopedic procedure involving pins and plates has complications, the main one being infection of the bone (osteomyelitis), although this is uncommon. However, we don't know how bad the OP's fracture was or what his original or current Xrays actually look like, so it is difficult to comment accurately. I do agree however that in most cases, bone remodelling occurs quite nicely, especially in young folk. Mind you, it has been a long while since I last did orthopedics, so I'm not the best source of advice. I think the important thing is, if you are still worried, or if the pain and swelling is bothering you, go back and see your doctor and ask for a fuller explanation, and if you are still not happy, a second opinion.
Originally Posted by milkpowder /img/forum/go_quote.gif If you want surgery, I believe you have two main choices. One is to put a metal plate over the fissure and drill nails on either side. The other is to thread a long piece of metal wire along the inside of the bone, or the cancellous/spongy bone. I think the wire will have to be taken out after the bone has largely healed and will put a permanent circular scar (albeit a rather small one) on your leg. The latter is a much smaller pin-hole-like surgery whereas the former is quite a bit more significant. The metal wire one does carry its own set of risks but I can't remember what they are off the top of my head... Your best bet would be to speak to your doctor about it. |
