Talonz
- Oct 18, 2003
Hi, I was finishing my mint amp today, and after putting it in the case, both channels worked great, but I still had to install the LED. After doing this (I took the board back out), the right channel no longer works. When both channels are balanced, the right channel is very very weak.
Attempting to raise the right channel volume on the computer results in massive distortion. Muting the right channel results in regular volume in the left channel and none in the right. Muting the left channel results in both channels acting like the right channel in mono with the low volume and distortion. Could it be that I blew out the buffer? I checked my wiring and for shorts, and no problems were found. Input voltages are standard, so it's somewhere within the amp. Is there any way to test to see if it was the buffer without taking it out?
Many thanks!
Many thanks!
