nightanole
- Dec 24, 2008
Well since MisterX and AMB have replied, my say is mute.
Ok In your world sound gets converted into 1&0's and put on a cd. Its then taken off the cd, ran through a digital to analog converter, and then the voltage is amplified and sent to a speaker. Your problem is you vastly oversimplified your problem.
In your world, the sound is recorded perfectly, converted to 1&0's perfectly, and converted back to sound and the voltage is amplified to power a perfect speaker.
I guess your argument holds alittle truth if the said speaker was a pure resistor and the signal never changed and was like say 60hz. Then all of these amps would basicly be just playing back and ac single into a light bulb, and the only diff between them would be how bright it got.
Theres alot more to an amp then just distortion numbers and watts. If that werent the case then all tube amps would be worthless. The amp has to also control the speaker and force it to do what it wants, and also reject all outside interference. A lower end amp might hiss more, or not beable to control the bass very well on a very reactive load speaker. a lower end amp and a higher end one might play the same freq at the same voltage just the same. Then try to vary the freq and voltage quickly, the lower end one wont keep up and will get muddy.
This is very simplified and odds are the wrong way to describe technical terms but i gave it a shot. To sum it up:
You act like a amp just needs to be a power supply, and a speaker is just a load/resistor. This is horribly incorrect.
An amps distortion and watts numbers have very little to do with how good it is.
PS: headphones are hyper sensitive compared to normal speakers. They are the most unforgiving sound makers out there so there is a reason why there are amps out there the size of a shoe box and only put out 2 watts...
