The only "path" from OL (or OR) to IG is the sum of R4L and R3L (or R4R and R3R). The opamp itself should not have any resistive path between those two points. Depending on what values you used for these resistors that's what you should measure. If it's not what you expect, then either you got the wrong resistors in there, or there is a partial short circuit somewhere (solder bridge?).
No you want "infinite" ohms reading between those points, not 0 ohms (which would indicate a dead short). Depending on your DMM, infinite could read as "OL" or just "1" (not "1.000").
I'm pretty sure I heat treated the lugs on that jack as my first reaction to my first set of wrong assumptions was that it was a bad jack, so I desolder-braided it. Got it squeaky clean before I decided it wasn't the jack and soldered it back. Clusterphuck is my last name.
Ok so I understand now what the checks are doing...looking for shorts right?
I'll just get a few more LED's and install them right this time.
So what temp do you set the iron for these teenie tiny little components? What size tip?
I used a 1.6mm chisel tip but wiping solder seems like it would be easier on those opamps with something smaller.
This is a nice amp Ti, maybe the next one I build won't take me as long
Your soldering iron tip should be ok with the proper technique. Did you use flux as instructed? Flux is the magic sauce for SMD work. Most of the time I set my soldering station temperature to around 350C for board-level work.
