dallasstar
- Oct 25, 2004
Test Rig:
University of Texas at Austin Dorm Room
Compal CL56 laptop assembled by Power Notebooks
Terratec Phase 24 FW soundcard
Astron RS-10A power supply
Sonic Impact Class T Amplifier
Signet SL 250 B/U bookshelf speakers
*I've managed to break my SR-60's during a modding experiment gone horribly wrong, and I've sold my Shure E3C's, so I will not be able to test using headphones for this review. However, I will buy some headphones in the future, and I may update this review and bump this thread at that time. I am sure that if I were to use headphones, I would be able to pick out the differences between soundcards more clearly.
Warning: Make sure to turn your amp all the way down when you get this soundcard. I stupidly did not remember to do this and had the crap scared out of me when i put on my first song.
The Package and Software:
As I opened the package, I noticed a great attention to detail in the included products. The firewire cable is of high quality, and all adapters necessary to make use of the card come right in the box. It even includes a leather case with the card (possibly fake leather; can't tell). For the price, though, this should be expected (I was able to find it for 189 on www.compumusic.com ). It comes with a driver CD, and I was able to install the drivers without problems. I noticed that the product functions independently of windows mixer. I believe Terratec has stated that this effectively bypasses the windows kmixer (I don't know the details; sorry if I'm overgeneralizing). The Terratec card uses its own software that controls the soundcard. So far, I have not had any major problems with stability or anything to that effect with this card. However, I should note that I have not been able to get kernel streaming and asio output to work in foobar yet, but I'm sure I will be able to do this after a bit of messing around. I will post a tutorial if i ever figure out.
The Features:
All features can be found here: http://audioen.terratec.net/modules....=article&sid=5
Some that I found particularly noteworthy are:
Balanced output in the analog outputs in the rear of the card.
Headphone output capable of 2 volts RMS output.
Capable of working as a stand-alone DAC.
Can work using power adapter or directly off of a firewire port (given that your firewire port supports this).
The Sound (analog outputs in the back):
This is a highly subjective section of the review. I cannot guarantee that you will experience these same results. I will note that my point of reference when I refer to "better" or "worse" is the Philips Aurilium USB soundcard, which uses the AK4353 DAC, which is the same one used by ESI Gigaport AG (in case some of you have experience with this card, but not the Philips). Overall, this card is far superior to any card I have heard in the past (I have heard Audigy series, Philiips Aurilium, SB16, Turtle Beach Santa Cruz; not heard the EMU's or any other high ends yet). The following are my more specific observations:
Vocals are far smoother
Bass is tighter and much more defined - not as flabby
Soundstage is considerably more realistic, and slightly larger. In particular, atmospheric effects seem more concrete, realistic and tangible rather than sounding like a synthesizer of some sort.
Imaging is very highly improved
Instrument separation is very highly improved
Sounds of pianos and xylophones (and similar) sound much more realistic
The highs are far cleaner, and slightly smoother: orchestra sounds are much less harsh than before, and much more refined and realistic
High end extension and low end extension are far far far improved
Drums no longer sound synthetic. This card makes them sound much more like they do in real life: the decay and bass impact associated with drums in particular are highly improved.
Songs which were used to notice improvements:
Nightwish - Nemo: Shows the highly improved clarity of the highs and the realistic nature of piano sounds. Previously, the pianos in this song sounded somewhat muddy, and they sounded synthetic; I didn't even know they were pianos till I watched the music video. However, after I switched to the Phase 24, it was readily apparent that the sound I was hearing was that of a piano being played.
Utada Hikaru - Simple and Clean (remix): This song displays the vastly improved soundstage and imaging, and much better defined bass.
Red Hot Chili Peppers - Zephyr Song: Shows improved high end extension. Previously, there used to be a background hiss with this song on all other cards I tried, but I knew that such a popular band wouldn't include such badly recorded songs in their CD, so I figured that the soundcard I previously used had bad high-end extension. This turns out to be true because the background is absolutely clean with the Phase 24.
Snow Patrol - Run: The improved sound of drums (and guitars) is readily noticeable. They no longer sound synthetic.
Utada Hikaru - First Love: Shows smoother and "breathier" vocals than before, and the clarity in the high end is displayed very well in this song. The bass in this song is also noticeably more defined and tight.
Sarah McLachlan - (Entire "Mirrorball" CD): This live CD displays the soundstage very well. I can even begin to pick out the locations of individuals in the audience after this upgrade
Eagle Eye Cherry - Save Tonight: I honestly can't say what specific improvement I notice in this song, but it seems much more enjoyable. The background vocals that I never noticed before even on headphones are now becoming clear and readily apparent, and the sounds are more realistic.
Enigma - Mea Culpa (and the Mea Culpa: Fading Shades remix): The improved soundstage is readily apparent. As mentioned earlier, the atmospheric effects are far more believable now. The improved bass also becomes very noticeable as the song progresses: it is noticeably punchier and smoother. The improvement in xylophone-like instruments also becomes apparent as the song progresses.
The Cranberries - The Rebels: The vocals are much more pleasing to the ears, and there is much more instrument separation.
Note: I'm very sorry that I don't have a much more audiophile "previous source" to compare to (such as EMU or Waveterminal cards), nor do I have many many years of "audiophile experience." You can take this review as you will. I hope that someone finds it helpful. I have used the card for 3 hours nonstop while paying attention to the sound before writing this review. Please leave any comments in this thread.
The Features:
