Mini^3 Quiescent current check problem
Aug 3, 2009 at 7:25 PM Post #2 of 8
Proceed to the rail splitter and DC offset "checks" and report your findings.
Pictures also help.
Aug 3, 2009 at 7:45 PM Post #3 of 8
Hey MisterX, thanks for your reply
I'll try to get some pictures later, but in the mean time:
1) Rail splitter:
on V- and V+, 6.83V
on V- and IG 3.4V
2) DC offset check:
on OG to IG ~ 1mv, then it slowly drops to 0
on OL to IG ~ open
on OR to IG ~ open
opamp dead
Aug 3, 2009 at 8:58 PM Post #5 of 8
If you have the multimeter set to mV DC try putting it to the hundreds range (200), to see if the offset is somewhere in the tens.
And do try reflowing those joints (pins 5, 6, and 8) on the AD8397
Aug 15, 2009 at 4:25 PM Post #6 of 8
Hi guys
I haven't been home lately so I didn't get to work on it, but I took another look this morning.
I reflowed the chip like you suggested ShinyFalcon, and well I think a few things got sorted out, however the current check still reads at 100.
Redoing the dc current check, it now reads:
on OG to IG ~ 4mv
on OL to IG ~ open
on OR to IG ~ in the decimal places
I figured it wont hurt to plug it in, so I tried it with some audio source, I can hear sound coming from it but the output constantly crackles- if that helps at all for any diagnostics.
edit: and the left channel doesn't work
Aug 15, 2009 at 6:40 PM Post #7 of 8
From my bad experience with AD8397, it can easily be fried while you're busy soldering other components. If you're pretty sure that there're any cold joints, it's probably time to say goodbye to it.
Hope this is not the case.
